Question about Proform 595LE Treadmill Walking Belt
Pro-form 595le seems to run loud from when I first had it. Anything I can check out or adjust on it? Sounds like my table saw. Loud Motor?
  • mike cooney May 22, 2011
    That is great information!
    Many Thanks for the response!
    MC
  • 5,370 Answers
The motor is getting weak or motor is getting stuck jam.This can cause the noise.Also if the treadmill belt if its getting dried internally then .It will be tough for motor to spin this dried belt and this can also cause noise. Under the treadmill belt in the inner side there a a oily grease substance which keeps the belt fluent And makes it runs smooth/.If that greasy/oily material gets dried up, then this types of problem can occur.So first try lubing the treadmill belt.You can get this material from home depot store.Done use normal oil or other greasy materials.You can use silicon lubricant for treadmill belt lubing.If that is not helping, then yes its motor problem.The motor is getting jammed or its time to replace motor.You can spray wd-40 spray on the motor inside parts and see if that is helping. ------------ For more troubleshooting the belt servicing procedure.Please click the link below:--- http://technoanswers.blogspot.com/2011/05/proform-595le-treadmill-walking-belt.html ---------- This should help.thanks.Helpmech.
Posted on May 22, 2011
Screeching noise
Not sure which saw you have, but you should first see where the noise is coming from. If this is a belt driven saw, then slip the belt off of the motor (you can leave it on the saw arbor) so that the motor can turn alone. Run the motor and you will quickly find if it's the motor or the saw awbor (that's the shaft that the blade mounts to). The motor might have oil caps. Post again your results if you still need help.
Good luck.
Nov 18, 2012 | Craftsman 10" Table Saw
Motor makes loud binding sound then trips. shaft turns slowly like in a bind as well.
sounds like a bearing in the motor, possibly brushes need replacing also. But most definitely a bearing.
Sep 14, 2011 | Craftsman Saws
I probably overloaded my 10"
Check if the shaft might have bent. Check if the blade runs true... Remove and re-install the blade as it might have been knocked off center. If the shaft got bent, probably you will have to replace the shaft/armature.
Jan 11, 2011 | Craftsman 10" Table Saw
I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Jul 31, 2010 | Proform Exercise & Fitness
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
Nut that holds the blade loosens after one cut. saw also runs loud and rough. believe is it related to the "gears" and cause of the nut loosening.
Sounds like a bearing is shot and rattling up the works there. Rock the blade back and forth and see if there is any play in it, check the bearing at the other end of the shaft. Is this one of those skil saw motor saws? Or is the motor hanging down below the blade? Need to know that before I can tell you what it is.
Mar 14, 2010 | Craftsman 10" Table Saw
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
My table saw will turn on, but sounds very loud
Possibly bearing wear, or the blade rubbing against the guard/housing. Unplug the saw and spin the blade slowly by hand, if it feels notchy then I would suggest bearing wear. if it only seems to feel notchy in places then it could also be damaged gears.
Oct 24, 2008 | Saws
Proform 595LE Treadmill Walking Belt Logo
323 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
