Question about Samsung Televison & Video
The display on my UA55D7000 stopped working properly after about an hour after initally setting it up. Sound still works but screen will only display a sort of multicolourd static snow. No menus or logos or images are visible. Have tried unplugging it all and setting it up elsewhere but no effect. Seems to be a manufacturing defect/fault. Any ideas short of sending it back to the retailer for replacement?
  • 105 Answers
SOURCE: 1080p doesn't work on PS3 and LG 42 inches LH4000
You appear to be correct. HDMI Timing issue with PS3.
1. Try a different cable
2. Try a shorter cable
3. contact TV manufacturer and report it.
I am guessing this may be corrected by replacing the cable. HDMI cables use different gauge(Thickness) wires and different shielding, so with some inferior cables there may be noise. This will cause picture problems. Don't let name like "monster" fool you, you Must try a different cable. If this is a TV problem, I would guess 100% that the TV manufacturer is aware and already created a fix if so. PS3 is so popular as the choice Blu-ray player that it is tested will all products sold. Almost used as a baseline for correct operation with BluRay and HDMI devices.
Posted on Jun 08, 2009
techman
  • 3130 Answers
SOURCE: Insignia NS-32LCD...Manufactured 2-07
This set should still be under a manufacturers warranty. This set has a board that is very hard to get. Do not let them tell you to wait, or you will wait and not get the set repaired. You need to call and have them repair or have them replace the set before the warranty runs out. If you do you will have a hunk of junk.. Good Luck
Posted on Sep 12, 2007
rockfixya
  • 679 Answers
SOURCE: SOUND BUT NO PICTURE
You almost certainly are between a rock and a hard place. If you have to come here to ask this question (and no offense is intended or implied), you probably won't be able to do anything to repair the unit yourself. What you can do is call around to some local shops and describe the problem and see what kind of repair costs you might incur having it repaired.
Posted on Feb 07, 2009
  • 304 Answers
SOURCE: About a month ago, our HP-R4272 stopped turning
It is possible that there is a loose connector inside of the set. BUT if you are not a trained tech have a trained Samsung tech troubleshoot the set because there are thousands of volts inside and will bite you, I know.
Posted on Jul 16, 2009
SOURCE: Our LG 26LC55 TV has just stopped working.
I have just fixed my own LG 26lc55 flatscreen.. with the problem of the red light is on and when i turned on the tv, nothing happened not even back to the redlight..
Solution-- take off the back panel, in the middle there is a brown " plate " with a lot of electronics, one of the black capacitor is burned out. if you look closely at the top you will see one of them is broken " the + on top is open " in my case " maybe all ", it was a 3300 uf, 105 degree, 10 volt capacitor, i took it of bought a newe one at a electronic store " 3 $ " and put it in. took 10 minutes and my tv is now working.. BY THE WAY, i could not find the exact capacitor, so i bought a 3300uf, 105 degree, but 16 volt. and it works like a charm.. REALLY HOPES THIS WILL HELP YOU..!!
Posted on Oct 28, 2009
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
Mar 08, 2015 | iPhone 5c Cell Phones
Can hear sound but cannot see picture
Hi, if your LCD projector turns on and projects light with sound but not the picture on your computer screen, first make sure the projector is plugged into your computer. If it is, check your computer display settings. Go to "Control Panel" and "Settings" or "Windows Setup." Select "Display." Make sure it's set to appear on your laptop screen and the the projector screen. Most laptops have a "Fn" key dedicated to changing the output display setting.
If your projector turns on but emits no light or picture, replace the projector's bulb, often called the lamp. Most have a life of between 2,000 and 6,000 hours. Your projector may warn you when the lamp life is about to expire, although some models simply stop working when the lamp needs replacing.
Thank you.
Jun 06, 2012 | InFocus Proxima UltraLight DX3 Multimedia...
Hi, My panasonic SA-HT940 IT IS READING INIT WHAT DOES THAT MEAN.??
check system output by aux port if output is normal then system amplification work proper
try another cd all cd it reading or init then lense clean with lense cleaner and try
May 18, 2012 | Panasonic Home Theater System System
1270 e MAKING a shrill sound and screen says parameter init. Had to unplug to make sound stop. Still says parameter init when plugged back in
It may need to be reset.
Please try to unplug it. press & hold the menu/function key while plugging it back in. When lights are blinking release it then press 91. and then display will show parameter init then change to maintenance. Press 99. The display should show date & time.
Hope this helps.
Mar 28, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
I just switched over from cable to an HD antenna. Everything was working fine for about an hour, but now my SHARP LC-42D62U is stuck on channel 21.2 and none of the buttons on the TV work (including the...
The tv needs to be rebooted then when you scan for channels you will need to manually erase 21.2 from the tuner, and call your cable company to report that this is happening.
Call 877-332-7867 to have a case file created and to be walked through an INIT so that the television will be unfrozen. You may need two people to complete the INIT/factory reset because in the beginning you'll need to be able to unplug the television set and then plug it back in while holding down two of the side buttons.
Mar 05, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jan 13, 2011 | Panasonic SC-HT730 System
Not even loading screen
Does the digitalbox has an inbuilt harddrive?? /David
Jul 12, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
My screen saver is not working
go to Settings Inital Setup change DISPLAY TIME OUT to 2 mins or more. Hope this works for you. If not you might have to reset phone.
May 27, 2009 | Cell Phones
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
Display Monitor
my sound driver are not working
Sep 23, 2008 | Gigabyte Computers & Internet
Televison & Video Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
