Question about Refrigerators
My refrigerator samsung model SRS618DP Problem: the freezer is ok but fridge is warm,the temperture is 16c degree
Have you cleaned the dust off of the air filter? I try to clean mine every few months. Mine has a panel in the front on the bottom I remove . Then get in with a vacuum. Hope this will help . If not it cant hurt.
Posted on May 22, 2011
Westinghouse fridge warm freezer -25 degrees
ok the freezer should be at 4degrees f and the fridge should be at 37 degrees f...sounds like the compressor electronics need to be replaced
Jan 10, 2014 | Refrigerators
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
I need to change the water filter in my samsung srs618dp fridge freezer. I have the filter but cannot locate the internal part in the fridge i need to change.
For Samsung side-by-side refrigerators, there are two possible locations. One is in the upper right hand corner of the refrigerator. The other is behind the veggie drawer.
To access the filter, either remove the top glass shelf or the vegetable bin. Turn off the water to the refrigerator. If no filter is currently in use, remove the cap. If a filter is in use, remove the old filter. Turn clockwise to remove the old filter. Save the cap to reinstall if the fridge is ever used without the filter. Note the date when you put in the new filter and place the sticker on the filter. Remove the red cap from the new filter and align the unlock mark with the filter mark on the filter housing in the refrigerator. (Looks like an unlocked padlock with the u part turned 180 degrees from the rest of the lock). Turn the new filter counter-clockwise 90 degrees until the lock symbol (closed padlock) lines up with the mark on the housing. Use steady firm pressure - it will be hard to turn. This ensures a tight seal. Turn on the water line and check for leaks. If the filter isn't leaking replace the shelf or the vegetable drawer.
Samsung support for the SRS618dp is here: http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=2201&prd_mdl_cd=RS23DENS1%2FRAD&prd_mdl_name=SRS618DP&srchword=SRS618DP .
I hope this helps.
Jun 12, 2011 | Microwave Ovens
Hi, I have a Samsung Refrigirator SRS618DP, and both the fridge and freezer are not cooling. There is power to both sections. Could someone help me out here please. Thanks in advance
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Refrigerators
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My digital display reads 88 degrees for the fridge and the freezer. The 88 display on the right is flashing. None of the buttons work when pressed.
reads 88 deg/ ok is frig that warm also .. if so replace the p c control as it has gone bad . in some models they call it a jazz board . / there is a update and it works much better .. mm
Dec 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
