Question about Pioneer FH-P5000MP CD / Cassette Player
Fm stations in pioneer fhp5000mp
How do i set fm stations in my pioneer fhp5000mp
4 Suggested Answers
danjoethurau
  • 20 Answers
SOURCE: setting radio stations on pioneer DEH-525R CD player
Scroll to the station then press and hold the preset button.
Posted on Aug 07, 2008
danjoethurau
  • 20 Answers
SOURCE: setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
  • 124 Answers
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Posted on Dec 27, 2008
What station does the 12 cdx run on?
according to pioneer their are 12 FM frequencies (stations) they start at 87.9 mhz and go to 90.1 mhz (fm) in0.2 mhz steps select with your remote. and set station and enjoy your music.
Sep 23, 2012 | Pioneer CDX-FM1287 12-Disc CD Changer
I need to pioneer carrozzeria avic-drz99 boot dvd
ELECTRORAMA TRINIDAD HAVE THE BOOT CD TO FIX IT, THEY ALSO CONVERT RADIO TO RECEIVE LOCAL FM STATIONS..PH # 662-6387...DANIEL / DAVID...
Sep 22, 2012 | Pioneer Gd-f1 Carrozzeria Am/fm Car Radio
I am having KEH-P8900R/X1B/EW PIONEER, by default it is playing the radio station FM- AF, I am trying to change it AM, but I did not get sucess. Can you please advice, how to change it. Thanks &...
There should be a "band" button on the stereo. you may have to press it several times before you get to AM mode, depending on how many FM stations it will store in it's memory.
Mar 25, 2011 | Pioneer KEH-P8900R Cassette Player
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Setting channels for am and fm on pioneer rx 570
Hi gbrokaw
Generally speaking, you select the station you wish to store, then depress and hold down the preset button you wish to store it to. After a few seconds, the screen will blink, and the will be station stored. On to the next one. Try this and see how you get on. If you have any problems, I am happy to help you help you sort it out. Cheers
regards
robotek
Nov 07, 2008 | Audio Players & Recorders
Setting radio station to a channel on a Pioneer DEH-525R cd player
May 23, 2008 | Pioneer DEH-P2000 CD Player
Setting radio stations on pioneer DEH-525R CD player
Pioneer DEH-P690UB FM tuning problem
Pioneer have factory set your DEH-P690UB to 0.2Mhz steps to match the American FM frequency allocations. The fix is not casual as it requires complete disassembly of the head unit and repositioning of two surface mount resistors. This will void any warrantee and unless you're good at microscopic soldering could also ruin the set. I did however void my 2 year warrantee yesterday partly out of frustration and because I have the right SMT tools at work. Now my tuner CPU thinks it's in the Austrailian/Asian model DEH-P7950UB and is also compatible with UK stations. A previously hidden menu is also available where I can set either 0.1 or 0.05Mhz stepping for FM and 9 or 10KHz for AM BSM scanning. The rotary control now steps in 0.05's instead of odd 0.2's on FM Hope this helps.
Aug 23, 2007 | Pioneer DEH-P690UB CD Player
Pioneer FH-P5000MP CD / Cassette Player Logo
35 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
