Question about HP 530 Notebook PC
Hp 530 laptop having problem with bios password i lost of mine .but still all works fine for me.but now i facingsome problem related to cpu fan that its automatically goes off as xp boots .i might be thinking of check fan properties in bios.kindly help me out with then solutions of both the problems. Thanking you,
    Problem Solver:
  • 7 Answers
Usually "flashing" the bios will help. If you can go to HP's website and search for your particular computer's drivers, there should be one for your bios chip. Run that, and it should remove the password. It will reset it back to the factory default settings.
Another way to remove the password from the bios is taking apart the computer (may void warranty, just so you know) and removing the button sized battery from the main motherboard.
Good Luck!
Posted on May 22, 2011
The laptop hp 530 overheat while connected to power
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 14, 2011 | HP 530 Notebook PC
How to clear bios password through software
You can get a bios master password from http://www.unlockbiosrecovery.com/Unlock_HP-Compaq_Bios.php that is the same password that HP can generate. Unlockbiosrecovery.com only charge $20 and guarantee it to work, where HP is wants over $100.
Jun 26, 2011 | HP 530 Notebook PC
LAPTOP does not turn on. only fan runs.
Things to check first.
1. Make sure you have a new BIOS battery installed. Some computers will not start if the battery for the BIOS is dead.
2. The CPU may have overheated and no longer works. I lost a CPU and everything was dead.
3. A dead motherboard can also act in like manner.
Sometimes something will come loose on the motherboard causing a direct short which of course fries the motherboard and probably the CPU. Dropping a laptop can shake things loose.
My Daughter had this happen with hers. It was a 800 dollar HP Compaq and I had a heatsink come loose on my HP Compaq which fried CPU AND Motherboard. Beware of HP since they bought Compaq.
Jan 25, 2011 | Intel Computers & Internet
I need to reset power on password for an hp530 laptop
You should take a little risk, to reset password , because this password is the back door password behind the BIOS chip.
Click on the bellow link
http://repair4laptop.org/laptop_and_notebook_bios_password_reset.html
You need to to disassemble the note book ,click on the link
http://www.insidemylaptop.com/disassemble-ho-530-notebook-pc-remove-top-cover/
Hope it will help you.
Jan 07, 2011 | HP 530 Notebook PC
How do I reset HP530 notebook bios password?
call HP tech support and work with them to get BIOS master password. System BIOS password maintained in non-volital RAM cannot be reset without original password or Master generated by HP
Oct 11, 2010 | HP Business Notebook 530
Hp laptop 530 ask power-on password key
get register at laptopmasterpassword.net and got it solve. it is only for registered user
Sep 16, 2010 | HP 530 Notebook PC
How do i reset the bios password for hp 530 laptop?
Bios password, this can only be done by the manufacturers of the board
Jun 15, 2010 | HP Business Notebook 530
I'm having a problem with my hp 530 laptop.....the fan is running too high...how can i fix this???
some times this happens with hp laptops and can be resolved by updating the bios. Go to the HP website and check the drivers for you model and see if there is a newer version of bios. Also run the diagnostics on it and it will test to see if it is a fan problem or mother board problem.
Jul 15, 2009 | HP 530 Notebook
Bios password
move the 'clear cmos' jumper on the motherboard over one pin, then put it back and boot up.
Jul 25, 2008 | Computers & Internet
Hp 530 notebook cpu upgrade
It's not posible to upgrade to a dual core, the motherboard is a different design. Keep in mind that the processor, motherboard and memory have a matched frequency. If the processor doesn't match the board then it won't recognize it. Since the board does recognize the T2300, it may be that you need to match the memory in order to get it to boot. Match the memory by going to patriotmem.com and entering the model that the T2300 came from, it will tell you the memory frequency. If the memory matches the processor simply will not work with that board.
Jun 25, 2008 | HP 530 Notebook PC
HP 530 Notebook PC Logo
147 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
