Question about Canon PowerShot SX100 IS Digital Camera
When i turn it on, it stays black, cannot see anything, and yes i took the lens cover off.
    Sergeant:
    Champion:
  • 214 Answers
Hi let me ask you little more beside your description. would you check if you can see menu on lcd. if yes, then might has two cause. first is shutter doesn't open at initial power on position due to sand damaged or oil contaminate on blade. second is ccd unit or main pcb defective( more open to main pcb defective.) you could bring to your local repair shop. they will charge you around $85 to 135 if it is the problem... Good luck with you!
Posted on May 22, 2011
The screen stays black. Yes, I have batteries, I do get instructions and images for video or camera, but I can no longer get a visual of anything the camera is aiming at. It's like there is a lens cap on...
Look at the front at the lens. Turn the camera to picture mode. Point the camera at a light above you. Take a few pictures and watch the lens.
You should be able to tell if is functioning correctly or if its broken. It sounds like it has been dropped.
Your Friend,
Sleek Mouse
Mar 15, 2011 | Cameras
It suddenly crashed so I took the battery out. Now it does nothing except beep when I turn it on and the screen stays black! Help!!!1
The lens is stuck. Switch on and tap the edge of the camera against your hand quite sharply. The lens should eventually pop out and screen operate as normal. Make sure lens casing is totally clean before switching off.
Cheers
Paul
Aug 10, 2009 | Samsung L200 Digital Camera
Wonderwall projector has black spot in middle of screen
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Aug 08, 2009 | InFocus LP70+ Multimedia Projector
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Blackness?
Have you tried reading the instructions? How long did you buy it? Try to press the pad or stick like a button inwards. That is how I get the image to go on my digital camera. Did it work?
May 14, 2009 | Canon PowerShot A570 IS Digital Camera
Lens cover error
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
Protax DC500T Digital Camera lens won't open
It will need repairing.
Thanks,
Lee
Jun 17, 2008 | Cameras
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Lcd monitor screen stays black
there may have been some kind of damage to the lcd. sounds like you are going to have to send it in to have it fixed.
Jun 13, 2006 | Casio Exilim EX-S500 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
