I have an Akai s5000 Sampler with a broken data wheel. Is there a way to fix it... I can't seem to find the part anywhere.
How to connect s1100 akai sampler to a mixing board music amplier how to connect the jack plug into the right connections
You would come out of the S1100 l/r output jacks into your mixer line input jacks on 2 channels, one panned left, one panned right. Be sure to adjust the input pad on each channel to where you're getting a hot enough signal and that the channels you're inputing to are routed to the mixer's main outputs.
Dec 13, 2014 | Akai Music
Mackie 24.8.2 were do i hook up my roland 808 sampler so i can recorder to the mickie
Grab the tape out leads or other mains jacks using TRS cables (balanced).
Jun 06, 2011 | Akai Music
We have an Infocus Screenplay 4805 projector. Our colour wheel has broken and we don't seem to able to purchase a replacement part from anywhere. Any help much appreciated!
Same problem... The manufacturer actually does not sell this part. You must simply purchase one off of craigslist or a broken projector and fix it with the parts. Here is a website that shows you how. http://home.comcast.net/~jexkids/Ebay/colorwheel/How_to_replace_Color_Wheel.htm
Nov 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
Akai s6000 sampler unused for most its life. Just when we need it it fails on the third full day. On power up the display is blank and all led buttong thats 8 under the screen stay fully lit. Power supply...
Same problem with an Akai S5000.
Display gets darker because power supply outputs for the mainboard starts falling after start up.
Don't know if its the mainboard is causing the problem or is a problem of the power supply itself.
A S5000 service manual will be helpful.
Best regards
Jun 10, 2008 | Audio Players & Recorders
Battery compartment door is ok but the teeth on the camera are broken. is this repairable?
You would have to replace the inner housing to replace the latches.
Fuji USA might have a fixed rate for this, here is the link to the support page for the S5000: FujiFilm
Mar 24, 2008 | Fuji FinePix S5000 Digital Camera
916 people viewed this question
 Grubhead
Grubhead
