HARD DRIVE AND PCI SLOT
FIRST TIME BUILDING PC.
WHEN POWERING UP HARD DRIVE DON'T COME UP. THE PCI SLOT DON'T DETECT MONITOR.
HELP!!
ecs elitegroup pt800ce-a
Driver of a herd drive
Posted on Aug 15, 2008
What memory and processor use Q35T-GB
Socket Type: LGA775
Supported Memory: DDR
Onboard Video: yes
Onboard Audio: yes
Graphics Expansion Slot: PCI-E x16
PCI Slots: 2 PCI, 1 PCI-E x1
USB Ports: 6
VGA Ports: 1
This should be the homepage:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2654
Good luck
Mar 16, 2013 | ECS Q35T-GB Elitegroup Type Motherboard...
I dont know how to setup gt 430 in pc
It appears you having a low profile model graphics for a desktop type case.
The EliteGroup board your have would be installed on the th PCI 16 slot on your mainboard.
According to EliteGroup, this model board is supported for XP systems.
There are normally one or more of four types of slots, AGP, PCI-E, PCI 16 and then just PCI. If your will check, the AGP is red or brown in color, the PCI 16 will be white, the slot will have a clip in on the right side. Be careful and make sure to seat the board and then clip on.
Please please copy and paste the following address into your browser ,http://www.ecs.com.tw/ECSWebSite/Produc/Product_Detail.aspx?DetaillD=1196&CategoryID=5&MenuID=25&LanID=0, to go EliteGroup support page for drivers and or any information about your model praphics board.
Good Luck
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=1196&CategoryID=5&MenuID=25&LanID=0
Aug 26, 2011 | EliteGroup ECS NGT430C-1GQR-F GeForce GT...
Not decting my sata burner sometimes
i do not have the motherboard driver for this specification of motherboard
Apr 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Monitor doesnt come on--just installed ecs a780GM mobo
Recheck all the hardware connections.
If it fine check the your CPU with another monitor. If it not works then fault with the CPU or software.
Hope this helps.
Feb 07, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
New ECS G31T-M won't recognize IDE devices
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Oct 13, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
3 long beeps of my elitegroup ecs green 320
If you cangatehr this much of information you are no less than a computer engineer. Nobody needs to build a car to change its tyre. If you arrange a spare HDD and RAM, remove the original HDD and try to install windows on that. And if problem persists do the same with RAM also. I am sure you could solve this problem yourslef.
Oct 06, 2007 | EliteGroup ECS G900 Notebook
755A
You didn?t give a whole lot of information to go on but if the problem is just slow drive detection you can speed things along by deactivating the IDE drive slots that are unused. For example if you have one hard drive on IDE channel 0 and a CD device channel 1 disable the secondary spots on each channel, it will make the drive detection faster. If that doesn?t help give us some more specifics about your current configuration and we can pickup from there.
Mar 06, 2007 | EliteGroup 755-A (ECS 755-A) Motherboard
Computers & Internet Logo
369 people viewed this question
David Payne
David Payne
