Question about Home
My samsung triflow SW95ASP washingmachine displays dE what does this mean.
Hi try the magnet on the right underside of your lid.mine had come loose as the lid is corroded. just tape or fix it back into place. this fixed my machine
Posted on Jun 30, 2011
What does the error code dE MEAN
you have not said what your washing machine you have.so this is for the samsung.
If the Machine is displaying "dE" error, kindly check for the following : First and foremost the door must be properly closed. You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact). Also, you can check the end of the drain hose is submerged in water.7 Mar 2014
'dE' Error is displayed on the panel of the Washing Machine? - Samsung
www.samsung.com/in/support/skp/faq/135992..if yours is not a samsung then please let me know.
Nov 20, 2016 | Washing Machines
What does PE means on a Samsung washingmachine when switching on?
The control board is detecting that the clutch motor is not working correctly
Jul 13, 2015 | Samsung Washing Machines
How do i remove my detergent dispenser on a samsung triflow sw95asp? I have tried everything and cannot find any clips etc. please help!!
This is covered in the owner's manual. You can get a copy at: http://www.manualslib.com/manual/147737/Samsung-Sw80asp.html
Jun 19, 2015 | Samsung Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Hello. I have samsung wf8604nwg washingmachin.and now theres a message that says HEI at the screen. what can i do to fix this?
WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
Jan 01, 2011 | Washing Machines
Washing machine Samsung Triflow SW65ASP not spinning anymore
I had the same problem it was the pump filter on the back. unscrew it and clean it. That worked for me.
Jan 19, 2010 | Samsung Washing Machines
Hi I have a Samsund Washing Machine SW65ASP2 triflow and i put a load on and it went find. Went to do another load and it came up with Code DE
DE is a door lock error it could be the door hasn't been shut firm enough or the door lock may have failed. Sometimes the pin that goes through the handle and ****** comes lose the door would have to be taken apart to check for that and in some rare cases the main module can be faulty.
Dec 20, 2008 | Washing Machines
Home Logo
219 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
