What does El Telco Loco mean on my tablet - Computers & Internet
Do you have blank magstripe cards
Yes we do. Order minimum is 100 cards.
$25 for Low Coercivity - LoCo
$35 for High Coercivity - HiCo
What does Coercivity Mean?
Coercivity is the term used to designate how strong a magnetic field must be to affect data encoded on the stripe, and therefore, how immune the data is to damage.
Measured in Oersteds (Oe), the coercivity of a common credit card is about 300 Oe, considered low coercivity. Consequently magnetic money clips, refrigerator magnets, etc., play havoc with the data on your credit card's stripe. High coercivity (HiCo) magnetic stripe technology relies on particles -- generally barium ferrite (low coercivity uses iron oxide) -- with coercivity values ranging from 2500 to 4000 Oe.
The encoding technique is the same as for LoCo technology, except that it requires a stronger electrical current in the write head. Virtually immune to domestic-type magnets, HiCo substantially decreases the chances of accidental data erasure. Despite this superiority, HiCo hasn't yet replaced LoCo technology, due to the widely established base of LoCo encoders and the increased cost of HiCo encoders. Standard magnetic stripe readers, however, can read either HiCo or LoCo stripes.
High-coercivity cards are currently used in applications where the need for performance, for example in critical test equipment, outweighs price. A single magnetic stripe can hold several tracks of recorded data, which can be rewritten and updated. The ISO\IEC 7810, 11, 12, and 13 series of standards specify a three-track format, encoding scheme, and bit density for all financial card applications.
http://www.smartcardsupply.com/Content/Cards/magstripe.htm
Jun 21, 2016 | Computers & Internet
Mi celular pantech 9070 prende y apaga solo
Hard reset the phone. If that doesnt work, then change the battery. Dificil restablecer el telefono. Si eso no funciona, a continuacion, cambiar la bateria.
Apr 02, 2014 | Pantech P9070 burst
Brio train 512
Depends what you mean by small hills? Has the loco climbed these small hills in the past without problem? A one in twelve (one inch climb for every twelve inches travelled) incline is about as much as this loco could manage I imagine, and even less when loaded with box cars etc. Sadly the traction drive on these loco's seems to have a short life. I have heard that giving the loco a good firm solid whack down onto a hard surface may get the internal gears to settle down and get more traction. There's an average chance it might work. Do not attempt to open it up, this will create a real mess because it's just about impossible to get all the minute loaded springs back into their correct place.
Jan 06, 2014 | Crafts & Hobbies
Android 4.0 users manual
arrows one points up one down, what do they mean
May 30, 2013 | Toshiba AT100-100 TABLET THRIVE
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
Some times my indicators work, then sometimes they dont work. Why is that?
when they work just dont use the hazards ,yes i know that being spanish you beleave that the hazards give you power to park where you like ,but i think you have a faulty hazard switch which is causing your indicators not to work .Estas una cosa yo encuentro mucho especial en espa?a donde alguno gente apacardo quel queries ,blockiado el camino pone el luces de emergencia ,esta acciona vuelve mi loco
Oct 31, 2010 | 2005 Dodge Durango
Tengo un tv sanyo avm 141m q no enciende y me tiene loco.agradeceria ayuda
Tengo un tv sanyo modelo avm-141m necesito el diagrama electronico, tienen mala recepcion, selector sospechoso,
gracias
Aug 12, 2010 | Sanyo Televison & Video
Mi problema es que al amanecer enciendo mi f150 modelo 95 se comienza a sacudir sufriendo aceleracion y esaceleracion del motor el tablero se pone loco el indicador del alternador sube y baja y yega el...
Sugiero revisar sistema de envio de combustible, presion de bomba, asi como componentes que mantienen el minimo (ralenti) del vehiculo. Descartado eso, verfificar sensores IAC y oxigeno.
Oct 19, 2009 | 1995 Ford F150 Styleside Regular Cab
Tengo una DN hd2500 y se bloquea
bueno, la cosa esta asi, basado en lo que a mi me ha sucedido, yo uso la dn2500 y  le doy mucho uso, a mi me *** ese mensaje varias veces, db save ng! , cant acces, eso es cuando tu disco duro esta fallando o ya murio o no lo puede encontrar, pero cada ves que me paso eso fue llegando al lugar de trabajo, me volvi loco , desconecte el teclado y la volvi a prender y se solucionaba hasta que un dia no arranco mas, entonces saque el disco duro interno y lo quise poner en una caja para copiar la musica a otro disco duro, hecho esto volvi a poner el hd en su lugar y funciono, yo creo que es un tema de los conectores, pero tambien podes ir a utilidades y probar hacer una base de datos nueva. lo importante es sacar la musica que tenes ahi, despues te compras otro disco duro($40) y lo cambias por el que esta ahi adentro o lo usas por usb externo, recuerda que el usb externo tiene que estar formateado en fat 32. aca esta mi email por si necesitas algo matosfilms@gmail.com
May 04, 2009 | Denon DN-HD2500 MP3 Player
Numerical Error Code 161 and 163
have you tried doing it in BIOS? coz the battery causes that
Mar 17, 2009 | IBM ThinkPad 380ED
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
