Question about Dryers
Hello My mothers amana ngd720tw dryer wont get hot and gets a error code hE does anyone know this code
3 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Amana Heavy Duty Dryer turns on and gets hot but wont turn inside
watch the video
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 10, 2009
heatman101
  • 43501 Answers
SOURCE: i have a amana dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 15, 2011
Amana dryer model # NED7500VMO Dryer wont work, error code F01
Disconnect all the plugs from the main control board and plug them back in to be sure you have good connections, if this doesn't work... order part # WPW10174745 Amana Dryer Main Control Board WPW10174745
Jul 14, 2016 | Amana Dryers
I have a Amana tandem dryer Model# NED7300WW1 that is stuck on delicate cycle. Dryer is heating and works but can't change setting. Any idea what it could be be?
Hello. From what you're describing, it sounds like the user interface board(fancy name for control panel) is defective. The part number for it is W10215814 and is #9 on the Pic 1 exploded parts diagram. The sequential pics show the procedure for entering diagnostic mode, interpreting error codes, clearing codes, and testing different parts of the dryer. I hope I helped you!
Sep 30, 2015 | Amana Dryers
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
I have a amana dryer ale643rbw that wont get hot and wont shut off.. do you know what the prob could be?
heatman101
May 16, 2011 | Amana ALE643RB Electric Dryer
We have an Amana LE9207W2. We start the dryer and within minutes it stops with an error code of SH. Do have to tell you that the dryer would seem to get overheated and shut down. That had been happening...
Hello- The error code is for an "Open Thermistor". You will need to have a Tech out to replace it. The part is about $30. As well, take a look behind the dryer and see if the flexible vent has been crimped or crushed and if so replace it. You can get this 4" ducting at most hardware stores. Also check the air flow on the exterior of the house where the dryer vents to. You should be able to feel a good amount of air coming out when the dryer is running. If little air is coming out and the ducting runs a good distance through the wall you should have a duct cleaning service out to clean it. Any issues with the venting of the hot air can cause problems with the thermostats and thermistor as well. Hope this helps, best regards.
Sep 27, 2010 | Amana Dryers
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
Amana model# lg8219w2 won't heat
need to have a gas line running to it.
Apr 27, 2009 | Amana ALG331RAW Gas Dryer
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Oven wont work. code comes up "5ab"
Hello thank you for choosing FixYa.com I am David.
I am no to sure what the code was that you typed in but here is a site with codes for amana ranges maybye one of thes codes will help you determine the error.
http://www.repairclinic.com/0078.asp#Amana
Nov 07, 2008 | Amana Kitchen Ranges
Dryers Logo
26 people viewed this question
Top Dryers Experts
