Loewe xelos has stopped where is the fuse so i can check? is it in the power lead [in plastic bubble'] jon
5 Suggested Answers
  • 188 Answers
SOURCE: Loewe Xelos TV 7 years old - screen image has
look for an square transformer near the LOT,underneath the transofrmer there is a resistor that can be defect.Measure al capacitors in East West circuit for bad capacitance.
Posted on Jul 27, 2009
  • 2239 Answers
SOURCE: i need to replace the gas bubble on a McCulloch Power Mac model 600032-54.....32cc i don't want to break the plastic ring around the bottom that holds it.. Thanks
If its a remote primer, it is sold as an assembly and just clips into the tank, if it is on the carb itself it will be retained by the metering cove of the carb held with four screws.
Posted on Jun 21, 2012
vinceisaac
  • 2432 Answers
SOURCE: Loewe Xelos
just replaced bad capacitor in the power supply usually leak or bulged to its casing.
Posted on Jul 19, 2012
gopakumarg43
  • 75581 Answers
SOURCE: Why is my colour TV (10 year old Loewe Xelos) only showing Black & White?
Its system settings should be checked. Refer its user manual for details. It it is multisystem one, set the system settings to 'Auto;.
Posted on Feb 22, 2013
Feb 22, 2013 | Loewe Televison & Video
Boash Axxis wta3510uc does not power up.
See this causes and fix it. God bless you
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Main Control
The main control board may have failed. To check this check the two main feed leads entering the control refer to the tech sheet located on your dryer. The two leads are usually a separate plug of heavy wire. Check to see if power is entering you should have 120 volts. If not the problem is not the control. If you have power coming in and nothing is illuminated the main control will need to be replaced or the Timer will need replacing
Oct 17, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Dryer is not turning on But washer is working fine
see this causes and fix it. God bless you
Door Switch
Wiring
Main Control
The main control board may have failed. To check this check the two main feed leads entering the control refer to the tech sheet located on your dryer. The two leads are usually a separate plug of heavy wire. Check to see if power is entering you should have 120 volts. If not the problem is not the control. If you have power coming in and nothing is illuminated the main control will need to be replaced or the Timer will need replacing.
Sep 28, 2012 | Washing Machines
Dryer wont come on
Door Switch
Wiring
Main Control
Sep 28, 2012 | Amana Dryers
Loewe Xelos
Jul 18, 2012 | Televison & Video
Battery was hooked up backwards. Have nothing electrical. Trnsy stuck in first gear.
There are fuses that have blown due to this, they need to be replaced.
Mar 06, 2010 | GPS
Loewe Xelos TV 7 years old - screen image has colla_psed at the sides so appears distorted viz )_( shape. Is it a write off?
Jul 27, 2009 | Televison & Video
New remote control unit.
You should try replacing the remote by buying a Logitech Harmony remote which you can then program to work your Xemix. It works really well for me. Alternatively if you can't get a dvd remote, try to get a TV control for a Loewe Xelos TV which has a DVD mode just for the Xemix dvd player.
Dec 07, 2008 | Loewe Xemix 5106 DO DVD Player
Will not switch on
If the sound is like an electrical arcing from the back left as you look at it the probable cause is the LOPT (Line output transformer) get this repalced and the set should be good.
If it as a clicking from just behind the front controls, the 5V standby transformer needs replaced.
Nov 01, 2007 | Loewe Aconda ACO9303 30" TV
Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Aug 08, 2007 | Loewe ARC332 32" TV
Televison & Video Logo
Top Televison & Video Experts
