Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Put new battery on 14 hp v-twin Briggs, started and ran for a while. Shut motor off then came back and tried to start, acts like the battery is dead. Where is the generator/altenator located on these?
  • 35 Answers
The generator is under the flywheel with or part of the ignition coil.
Check all the battery wiring and grounds. A bad or weak connection will act the same way.
Posted on May 22, 2011
Getting fuel in oil on 19hp b&s motor. Cleaned carb and drained oil, fresh oil and started motor, motor ran for 3 or 4 minutes then had to use a little choke to keep running and then it started...
How long did it take to do this job..did you clean the the carb first...then the oil or vise versa...the reason I as is ma y if these motors are equipped with an electric valve on the carb that go bad or stuck allowing the gas to continue flowing after shut down eventually in the intake valves and into the crankcase...causing smoke and high crankcase pressure and out the carb and exhaust...no use changing it WILL happen again..the fix is simple put an inline gas shut off and shut it off if only shut down for minutes...happened to my 18 horse Briggs...just shut it off every time you turn the engine off..Hope this helps..good luck..
Sep 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
B&S ELS 725 on a Husq 2448 lawn tractor - stoppe running won't st
There is no oil pressure switch to save the motor. You may be ok if the oil level did not drop too low. Change the oil, recharge the battery, put in a new spark plug and fresh gas. You may be lucky and have it start with no damage. good luck
May 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
193 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
