Question about Car Audio & Video
I have a 2011 honda civic lx 4-door sedan. I took the battery our to install new headlights. When I was done I hooked the battery back up & turned the ignition & the radio control panel said I needed a code. I pretty much used up all my chances cause now it says CODE ERROR E.can I please get some help here.
    Sergeant:
    Champion:
  • 226 Answers
Check the Honda Service History book the first page says 'Pre-Delivery Inspection' it should have the 4 digit pin written there..If you have it, disconnect the battery again, should reset and enter the code. If you dont have this, the dealer is the only that has the code. Im not sure what they will charge........but they dont call them stealerships for nothing. Good luck
Posted on May 22, 2011
Why doesn't this 2000 Honda civic lx turn over when everything else works inside the car?
Honda Civic Coupe Questions - car will not start. battery ok ...
www.cargurus.com > Questions > Honda > Civic Coupe
CarGurusJul 9, 2008 - Get someone to turn it over and see if it is getting spark. ... i have the same issue with my 1993 civic lx it has a 1.5 sohc non-vtec i changed ... comes wen the 2nd click of the main relay it doesn't occurs until after few minutes, few .... My 2000 Honda Civic Ex Vtec will not start, has a new tps, new throttle body, ...
Part 1 -How to Troubleshoot a No Start (1.6L Honda Civic)
troubleshootmyvehicle.com > Honda > 1.6L
Dec 31, 2012 - Difference Between a No Start and a No Crank Condition. ... can cause your 1.6L Honda Civic (Civic del Sol) to Crank but Not Start. ... In other words, the engine doesn't turn over at all. ... 1995, 1996, 1997, 1998, 1999, 2000.
98 Honda civic won't crank (PushStart) - YouTube
? 4:11
https://www.youtube.com/watch?v=X5W7OqjKB8I
Oct 21, 2013 - Uploaded by SkzDaniel
Honda Civic won't start or crank with the clutch but goes on when you push start it. ... 2000 Honda Civic LX with new battery and starter. Still will ...
? 6:34
https://www.youtube.com/watch?v=p7KAO__nM1s
Aug 21, 2013 - Uploaded by Robert SnyperMD
2000 Honda Civic LX with new battery and starter. Still will not start. ... Crank, No Start Diagnosis Honda Coil test. - Duration: 11:17. by ...
Jan 05, 2016 | Honda Cars & Trucks
Tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jan 28, 2011 | Honda Civic Cars & Trucks
I have a 1997 Honda Civic 4 door my dash lights are out and the dinging to my headlights is not coming on and I checked every light bulb and every fuse I don't know what to . Is is the dimmer switch
HONDA ILLUMINATION NOT WORKING * HOW TO FIX ...
? 3:24
https://www.youtube.com/watch?v=oOHwDWjmYWU
Feb 28, 2011 - Uploaded by vehix411
No lights,cant see the dash lights,bad bulb,how to change bulb clucter ... i have a 2001 honda civic i installed a new radio andmy cluster lights are ... I just bought the computer or (multiplexer whatever) for my 1997 accord because my back tail lights won't turn on but I ... Martin Nikolov 4 months ago (edited).
Removing a Honda Civic instrument cluster - YouTube
? 4:01
https://www.youtube.com/watch?v=kzp1VqdlmU0
Oct 28, 2012 - Uploaded by mike937739
George L 4 months ago ... I used it to fix my burnt out check engine light bulb in my 97 civic. ... I have no light on my dashboard I already replaced the fuse but still nothing? so I'm ....2005 Civic cluster in 1997 Civic working!
1997 Honda Civic Instrument Panel Lights Problem ...
? 1:26
https://www.youtube.com/watch?v=mYVt93Rao6g
Mar 26, 2013 - Uploaded by fockyoumang
Dec 16, 2015 | Honda Cars & Trucks
How to install the headlight bulb of honda airwave 2005? What is the right bulb for headlight
How To Install Replace Headlight and Bulb Honda Civic ...
? 12:34
www.youtube.com/watch?v=VybpBgoVTCg
Jul 13, 2012 - Uploaded by 1A Auto Parts
http://www.1aauto.com/1A/HeadLights/Honda/Civic/1ALHP00286 1A ... How To Install Replace Headlight and Bulb Honda Civic Sedan 01-03 1AAuto.com ..... JDM style headlight assemblyinstallation..2001-2005 Honda C .
Oct 11, 2015 | Honda Cars & Trucks
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
1991 Honda Civic sedan LX; tow hooks
It sounds like you are describing the standard tiedown hooks on many cars used to secure them to railroad cars, tow trucks, and ship decks. I've never seen them as an option on a new car. They may be referred to in the owner's manual under towing.
Jun 10, 2009 | 1991 Honda Civic
Fast Idle above 2000 rpm during warmup & electrical issue
If it's not vacuum leaks, it will be you idle control sensor.
May 08, 2009 | 1993 Honda Civic 4 Door
Need to replace headlight bulb in honda civic 2003
Dec 31, 2008 | 2003 Honda Civic
How do you install a driver side mirror?
hey, I replaced a mirror on a 2002 civic lx coupe.
1) Pry off the small pastic traingular piece from the interior of your door.
2) Disconnect the wiring to the mirror
3) There will be 3 bolts that attach the mirror to the car, remove these and the mirror can be removed. To put on the new mirror just do everything in reverse
Just make sure you order the right mirror, I accidentally order the mirror for the sedan model the first time and they are not interchangable.
Hope this helps
Jul 31, 2008 | 2001 Honda Civic
Car Audio & Video Logo
247 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
