Question about Breville ESP8XL Espresso Machine
Water leaking out of the tank
Hi there...our Beville cafe Roma has been working fine then suddenly I found a pool of water under the machine and the water tank was empty.
Any ideas please?
  • chriswood Dec 22, 2008
    I have the same problem. I have had it for 1 week and used it 3 times. I have noticed a puddle of water under it 3 times too. Thinking of returning it...it's brand new
  • Anonymous Mar 29, 2014
    Water leaks out the back of machine, unable to press start as there is no indication that water is in the tank, the little red lever goes up, no beep sound, and unable to start
    Connie needing caffeine
  • 515 Answers
i think you have to replace the gasket where the water tank fits, it´s very tight there, you have to take off the bottom from the machine then you will see two screw, loosen this.
Now can you put down your hand in the hole and take of the plastic above the gasket.
Hope this will help you.
/Mirran
Posted on Aug 15, 2008
My breville cafe roma wand is not steaming it is just making air bubbles
Have you tried cleaning out the machine? My steam wand started just spraying out a steady stream of water but was not heating up. I used the cleaning solution CLR (8 parts water, 1 part CLR) and let it run through the steam wand for awhile. At first it just kept streaming out then all of a sudden it stopped. I still kept it on just to see what would happen. After about 10 seconds all of a sudden the steam wand shot out whatever had clogged it and it works perfectly again! I had only used the machine about 10 times before this happened. I had not been cleaning it well after each use back then. Now I definitely do.
Sep 13, 2010 | Breville ESP8XL Espresso Machine
Miele CVA 610 coffee system says "water system fault" can I fix myself?
Hi I,am not 100% familiar with this model but the machine thinks the is a leak. Remove water tank the should be a hole visible under tank place finger in hole and check for water. If so remove water with syringe etc. Leak most likely cause tank incorrectly fitted or faulty seal on tank. If water tank seal OK, Remove water with syringe etc appliance will work. As a precaution remove lid and run you should be able to see any leaks. If not look for white stains on components. If no leaks or stains found it's was most likely tank incorrectly fitted.
Aug 22, 2010 | Miele CVA4070 Coffee Maker
How do I get my breville cafe roma espresso machine to pump water out of the water tank and through the machine? It won't create steam or brew coffee and the water level in the tank won't deplete when the...
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Dec 27, 2009 | Breville ESP8XL Espresso Machine
Cafe Roma producing more water than steam
you really need to decalc frequently, at least every 2 months. after it goes too long, you will see that problem. have not figured out yet how to fix it.
Jun 18, 2009 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Espressione Cafe Roma Espresso is coming out like foam!! Help!!!
I can understand how frustrating that can be. You might want to try and de-calcifying your espresso maker. After time the calcium and minerals in water can build up and clog the nozzle of the machine. You should be able to find a de-calcifying solution at a local cooking store. Also if you are trying to reach the manufacturer their number should be 770-509-3006.
Thank you,
Agent Matt
Go Ahead. Use Us.
Apr 11, 2008 | Espressione Cafe Roma Deluxe 1329
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
349 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
