Question about Sport & Outdoor - Others
I have a yamaha raptor 4 wheeler. I can not get it to start until I unplug the regulator module in the back or the conection plug on left side of machine. the electrical line comes from the regulator through the plug down into left side of engine. not sure what is in there? with machine running if I plug the lines together it will die Unplug and it will fire right up. Any help? Thanks RW
    Master:
  • 448 Answers
You most defiantly have a short you need to trace the wires down
and find out witch one is grounded
you may even have a bad alternator that's grounded or the regulator
the way they make things to day its very hard to test some units
its all going to be trial and error
hope this helps you
bob
Posted on May 22, 2011
WHERE DO I FIND THE SERIAL NUMBER ON A 2005 YAMAHA BRAUN 4 WHEELER
Yamaha ATV VIN plates, mounted on the frame, may be positioned behind the left wheel well, on the front of the ATV or on the left side beneath the shifter pedal, depending on the model
Apr 18, 2017 | Yamaha Motorcycles
1985 Yamaha three Wheeler 50 cc has no spark been setting awhile
Hi, Terryjoe if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue, please visit the websites below. Good luck and have a nice day.
No Spark Diagnosis Motorcycle 4 Wheeler Starting Issues Using Multimeter
Honda TRX 70 No spark fix try this FIRST
http://www.oscarmayer.net/atc/manuals
http://www.shareol.com/?s=1985+Yamaha+tri+zinger+50+
Dec 05, 2015 | Yamaha Motorcycles
My Yamaha raptor 350 makes a ticking noise once I move it down from nutral
2007 raptor 350 ticking? - Yamaha Raptor Forum
www.raptorforum.com/...raptor-350.../23854-2007-raptor-350-ticking.h...
Nov 30, 2007 - if its 100% stock then no there shouldent be any ticking, if its only 4 days old take ... as i got it up to crusing speed for a few minutes.. you'll get used to itsnoises. ... eng temp, rpm, custom one off intake, polished engine covers,. Ticking Noise - Yamaha Raptor Forum
Aug 5, 2014
2008 Yamaha Raptor 350 making grinding noise . . . - Yamaha ...
Sep 13, 2011
How To Avoid Hot Cam Ticking? - Yamaha Raptor Forum
Jan 30, 2011
raptor 350 knocking???? - Yamaha Raptor Forum
Mar 6, 2010
More results from www.raptorforum.com
Aug 01, 2015 | Yamaha Motorcycles
How to test stator on a Yamaha 225 Moto 4 four wheeler with a ohmmeter
3 yellow (or white) wires. Test lead to lead. Should be continuity. Then, test each lead to ground. Should be no continuity.
Should also check for AC voltage when running, lead to lead. Should get 40+VAC when revving up engine.
Do not plug in or unplug wires from stator to regulator while running.
Nov 23, 2013 | Motorcycles
Yfm 350 warrior air mixture screw is
this definetly seems like your float adjustment needs checking/resetting.
Jun 16, 2012 | Yamaha Genuine Yfm 350 Yfm 600 Yfm660...
Yamaha 2001 Raptor 660, need to clean my carb
Drain and replace the gas with fresh.
Remove the air cleaner and spray carb cleaner into the inlet. Work your throttle a little then put everything back together and try to start it.
Jun 02, 2009 | 2001 Yamaha YZ 426 F
Engine oil plugs?
Just oil,The same you run in the rest of the engine.
May 14, 2009 | 2004 Yamaha YZ 250 F
How do I adjust the valves on my 2003 Yamaha Warrior YFM 350X?
first you need to remove everything that covers your valve covers(gas tank etc.) remove the intake valve cover,and the rotor nut and timing plug.set the engine a t.d.c.(top dead center)fit a socket onto the rotor nut and turn it counterclockwise until the"I" mark appears align it with the index mark in the timing hole.use a flat feeler gauge between the top of the valve and the adjuster.loosen the locknut and turn the adjuster just until you feel resistance on the feeler guage.hold the adjuster and tighten the lock nut down.i can not tell you the min.clearance spec to your quad since i have a 660 raptor.try using the smallest clearance number.
Apr 24, 2009 | 2003 Yamaha YZ 250
Sport & Outdoor - Others Logo
21 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
