Question about Welding Tools
I'm tryng to find The manual to my Star Weld SW 1500 (140amp) Mig Welder. I brought it at a pawn shop but it had no manual. I need the manual to help me learn how to use it correctly, with gas and gassless etc. Thankyou if you can help
  • 1525 Answers
SOURCE: clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
Posted on Mar 27, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 5 Answers
SOURCE: The wire feed on my welder will not work.
Dale,
Probably the trigger/ open the lead and try to short the connections for the trigger by bypassing the trigger acuator. This is the mechanism that activates the wire feed motor and applies the welding voltage to the wire. If this works, get a new torch handle.
Posted on Jul 25, 2009
  • 7 Answers
SOURCE: Welder work OK with flux wire, cannot get penatration in MIG mode
Same here, just a tall cold bead in MIG mode using .024" wire and 75/25 gas
Posted on Nov 10, 2009
  • 105 Answers
SOURCE: SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Posted on Dec 15, 2009
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
I bought a Chicago Electric Mig Welder 151 T/2 from a pawn shop and I am just looking for a manual for it.
go to this link
http://www.harborfreight.com/120-amp-230-volt-mig-and-flux-welder-97503.html
click on product manual for download of the manual the link below may work as well.
http://manuals.harborfreight.com/manuals/97000-97999/97503.pdf
Dec 29, 2010 | Garden
I dont know what kind of metals this wire type can do, it says fire power 1440 u235 flux wire, but not sure what kinds of aluminums or steels it can weld. Im a certifed MIG aluminum welder, but this is a...
Usually a flux core only welds steel. It is a higher penetration weld than a MIG. Usually it acts similar to 6011 rods in SMA (Shielded Metal Arc) welding -- a.k.a. stick welding -- if you're familiar with that. I don't believe there is such a thing as flux wire for aluminum. There may be stainless wire for it, but I've never seen it. It probably could also be used for building up cast iron and cast steel, but nothing structural. I have a Chicago Electric one and I love it -- simple and it penetrates hard. My 90 amp will weld to 3/8" without breaking a sweat and if I baby it will go to 1/2" or better. It is difficult to go much lower than 12 or 14 gauge though due to the high penetration.
Nov 28, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Mig welding 1/16 thick metal
you should run power between 160-180 to get a godd weld with out burning your work
Jul 01, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Apr 05, 2009 | Welding Tools
Electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Nov 19, 2008 | Welding Tools
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Welding Tools Logo
258 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
