Question about Brother XL-5130 Mechanical Sewing Machine
The stitch on the bottom of the material is very loose and is bunching and looks terrible, the top thread keeps skipping and breaking, Ive fiddled with the tension and still having problems
    Novelist:
  • 233 Answers
Let me give you a general lesson on adjusting tension that will work for any machine. I suggest you thread the top of the machine with a different color thread than the bottom so that it's easier to see what adjustments you need to make.
Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
Posted on May 22, 2011
  • BARBARA SIPES Aug 07, 2012
    i have tried all of this and i still cant seem to get it straight.
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
What is the factory tension setting for the Brother LS-2125i sewing machine?
you probably wont find it listed anywhere as it is from experience and changes with different material thickness and needle size
SO how to set tension
thread the machine and adjust the tension until you feel a drag on the thread
now thread the needle and sew a piece of scrap material
if the thread bunches up underneath then increase the thread tension until it sews properly
if the bottom thread is pulled to the top or the thread keeps breaking loosen ti off a bit
when the stitch is being properly formed , both bottom and top threads should meet at the center of the two materials being sewn
Oct 13, 2015 | Brother LS2125i Sewing Machine
I have the brother CE5500PRW sewing machine. I
Are you 100% sure you are using the right size bobbin?
Sep 11, 2017 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
The top thread is looking good, the bottom stitch is bunching up
re-thread the top, when the top looks good but the bottom is bad it is the top thread
Oct 16, 2009 | Necchi Sewing Machines
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
633 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
