Question about Garden
The throttle control does not work on tecumseh model oh195ea
  • 10,515 Answers
The throttle plate will stay at wide open until the engine starts. If the engine will run at idle but not at high rpm you most likely have a carb problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 22, 2011
Our snow blower with a Tecumseh model OHSK120 snow king engine starts but runs full throttle!! Any ideas?
Stuck or bent governor, governor linkage or throttle. Try moving the throttle and see if all the linkages move with it.
Jan 25, 2017 | Tecumseh Garden
Tecumseh 195cc
Those are engine numbers not buggy numbers, use tape measure inside the pulleys to get approximate size then experiment with different sizes
May 29, 2013 | Mtd Garden
Tecumseh back fires but does not run
Have you checked to make sure the flywheel key is not sheared? If sheared it throws off the timing and will backfire when you try and start it. Somewhat common on those engines. If you have the engine model number I could look up a parts diagram to better answer the carb question.
Aug 19, 2012 | Tecumseh Garden
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
Just bought a tecumseh 5hp. horizontal engine on a leaf vacum (used)the engineb only runs @ full throttle or stop .nothing in between.throttle moves but there is no change in engine rpms.it may be a piece...
Much of the newer equipment is equipped with no throttle control feature. The engine runs at a governed pre-set RPM that enables it to do the most work at the most economical speed. This is particularly true of new lawn mowers (the push and self-propelled kind). If you would like to post back with the exact manufacturer name and model number of this machine, we can look for a parts diagram to identify exactly what fuel delivery system is has and how it is set up.
Jul 17, 2011 | Garden
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
