Question about Whirlpool LGB6300 Gas Dryer
I have a whirlpool das dryer. on the top edge where the door closes there used to be a little hunk of metal that clicked in when the door was closed. its on the top right corner (the dryers right) of the door frame at first if we dident wiggle it it might not let me close thr door. now its gone and the dryer wont come on at all. what is that part and can I fix it? Thanks so much!
  • 35 Answers
Door latch kit. Easy fix.
Door latch Kit
Posted on May 22, 2011
  • elainecaroll May 22, 2011
    This is great information except this regards the middle latch and the one that is not working on mine is the one in the corner. I can see it on this machine when they take the door off in the video. Its located on the machine but not the door in the top corner.
  • Uncle Eddie May 22, 2011
    My bad. I should have remembered this as I grew up with the same dryer!
    There was a rounded metal tab that was always getting bent until it broke off. One of my first repairs.
    It's the door switch. The metal has since been changed to a plastic tab in many cases.
    DOOR SWITCH is athttp://www.repairclinic.com/PartDetail/D...
Dryer won't stop when door opened
Possibly the switch on the door has bent far enough so that it will not disengage when the door opens. It may be stuck on the sharp edge of the metal. Look closely, dislodge if necessary. There are very sharp metal edges so be careful with your fingers. Recommend calling a "mechanically minded" friend or neighbor before calling a repairman.
Sep 03, 2014 | Whirlpool Dryers
My dryer does not turn on. I have power to the plug but the when I set the timer and then push the start button nothing happens (drum does not turn nor does it heat). The plug is fine and wires to the...
Hi Ken,
I recently wrote a short article about this for someone. I'll insert it here for you.
I would like to know what you found.
Best Regards,
Mark
Here it is.
When most Whirlpool dryers do not turn on at all. The most common cause of failure is the door switch and the door switch actuator.
Here is how you can test this.
1 Empty the dryer of clothes
2 Locate the door switch actuator. it will be over along the top edge of where the door closes, just inside the lip. There will be a little (3/8th inch wide) metal tab covered in plastic(or a plastic tab). This is the actuator that is mounted to the electrical door switch. The door switch is a valuable safety device that prevents children, pets and adults from loosing limbs and other things in a spinning dryer. DON'T BYPASS IT.
3 The tab may simply be broken off. If you can push the piece and hear a clicking sound, it means the switch is probably good but the tab is not.
4 To test this push the tab in or jam a ball point pen in there until it clicks, turn the dryer timer on and push the start button. It it comes on, that was the issue.
WARNING: NEVER, NEVER, NEVER PUT YOU ARM INTO A SPINNING OPEN DRYER DOOR.
JUST DON'T DO IT. IT CAN RUIN YOUR DAY.
5 If you push the tab and get no click but a sort of springy action. The switch is broken.
Usually the switch replacement kit has both the metal tab and the switch.
That is most often it.
If you can supply me with the model number of the dryer, I can help you locate the right part and give some instruction on how to do it.
Best,
Mark
Jan 24, 2011 | Whirlpool Dryers
My Whirlpool just quit it just won't turn on was working just fine is this something i can fix myself?
When most Whrlpool dryers do not turn on at all. The most common cause of failure is the door switch and the door switch actuator.
2 Locate the door switch actuator. it will be over along the top edge of where the door closes, just inside the lip. There will be a little (3/8th inch wide) metal tab covered in plastic. The is the actuator the is mounted to the electrical door switch. The door switch is a valuable safety device that prevents children, pets and adults from loosing limbs and other things in a spinning dryer. DON'T BYPASS IT.
That is usually it.
Hope this helps,
Best Regards,
Mark
Jan 05, 2011 | Whirlpool GEX9868J Electric Dryer
Whirlpool LEQ9030PQ0 electric will not start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Jun 03, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wil not run, buzzer does not buzz?
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
May 20, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not work
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks and clicks when you close the door then you have a bad thermal fuse. The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
May 18, 2009 | Whirlpool Dryers
Electricity getting to dryer, I hear a click, click, click sound, but when I press start, the dryer will not start.
May 18, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not start
Door switch part number 3406107
May 17, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer will not turn on. LER5636EQ3
Door switch part number 3406100
May 17, 2009 | Whirlpool Dryers
Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
Nov 02, 2008 | Dryers
Whirlpool LGB6300 Gas Dryer Logo
157 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
