Question about Yard Man Garden
I have a 4.5 yardman lawnmower and i cant get it started what can i do to fix this?
    President:
  • Yard Man Master
  • 1,545 Answers
Check for clean air filter, good strong spark and good fuel flow to the engine. The only other thing that could be out of whack and prevent starting is the "air-gap" between the ignition coil and the flywheel. To try and coax the engine into starting, remove the air filter and shoot a good shot of carb/choke spray into the carb throat with the choke off. Then immediately try to start the engine normally (with it choked). We are trying to get it to run so it will start drawing fuel normally from the carburetor. A clogged carb main jet can cause your problem too. It is the brass bolt that holds the float bowl onto the carburetor body. Remove it, inspect it and clean it. Use no metal objects on it as the small orifices that meter fuel thru it have to stay that way. Look for clogged holes in the unthreaded section of the bolt near the top. Clean it till shiny and reinstall. Try the carb/choke cleaner a few times and post back if needed. We are here to help.
Posted on May 22, 2011
No fire to plug was running new engine
How to fix a lawnmower no spark - YouTube
? 11:58
www.youtube.com/watch?v=ckyFlX4CUVU
May 1, 2012 - Uploaded by doublewide6 I got new spark plug still cant start my lawnmower any sujetions... Engine is hard to pull start and get to fire when it's cold but after it does start ...
Sep 19, 2015 | Garden
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 | Garden
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
My lawnmower will start but it idles high and shuts off.help!!!! its a mtd yardman/briggs stratton push mower
this problem you will have to take to a small engine repair shop it is harder to fix or to tell you what is wrong with out hearing it for my self it could be a few things make sure that you find one that the labor rate is low but the quality of work is good...
Jul 21, 2011 | Garden
I have a yardman riding lawnmower and cant get the blades off what way do you turn it?
they are reverse threads., so you will turn them clock wise (I just pulled mine off 2 minutes ago. use a 15/16 socket with a cheater bar and they come right off. make sure you jam a peice of wood, I used a 4x4 to hold the blade
May 21, 2010 | LG enV VX9900 Cellular Phone
I cannot get any speed from my MTD/Yardman riding lawnmower. I have change the belts. It will engage But just will NOT go very fast. It is a sem-automatic.
Your yardman mower is a hydrostatic model which uses a small hydraulic pump to turn a hydraulic drive motor.Check there is sufficient oil in the transmission. Check the forward/reverse lever travel, and adjust as needed to increase the "throw" to move the swashplate in the hydraulic motor.
Jan 04, 2010 | Garden
Mtd yardman riding lawn mower will barely move or not at all
rock it back and forth, and pull the shifter to neutraLwith out mtor running.
May 18, 2009 | THQ The Lawnmower Man
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
149 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
