Question about Microwave Ovens
How to change the power levels on a Oster Microwave Model: OM1201E0VG.
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Posted on Dec 30, 2009
  • 8909 Answers
SOURCE: The oster model OM1201E0VG model,
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 01, 2011
dcramer531
  • 1654 Answers
SOURCE: I have an Oster 1.2 cu. ft counter top microwave
There is still factory warranty on this and most stores wold even take it back if there is a problem. Please don't try and repair something that can be fixed under warranty or they will void the warranty. My advice is to put it all back to gether and then take it to the store you purchased it from and demand an exchange. They most likely will return it no questions asked if it is that new.
Posted on Apr 08, 2011
heatman101
  • 43501 Answers
SOURCE: I have an Oster Microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 13, 2011
I have a Oster Microwave (OM1201E0VG), it's almost like new, works but suddenly has NO HEAT. I would hate to get rid of it, only had for a couple of years. Can it be fixable or should I toss it?
You might want to check the door microswitches for proper function. My microwave ovens have four separate switches on the door, one controls the actual heating, and if that switch goes bad, no heat. They're inexpensive and easy to replace.
Jun 17, 2015 | Oster Microwave Ovens
My oster 1000 watts microwave is not getting hot
There is a semiconductor device called a triac, if food is warm the microwave is not running at full power because the triac is defective.
Apr 09, 2012 | Microwave Ovens
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
New oven model OM1201E0VG will not heat. Microwave worked at the store but I cannot get it to heat. Comes on but does not heat anything.
Call your dealer where you brought it. It's new purchase, you said it so, but read first operating manual.
That's the thing you need to do. I hope I help you.
Mar 29, 2011 | Oster Microwave Ovens
I have a new (30 day) Oster Microwave.I live alone,and recently tried to change the power level.No matter how gently I touch the power button,the bell rings twice.I can't seem to change power levels.Is it...
Most major manufacturers supply manuals and information online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and repairs as required.
The information is normally free of charge.
I hope this helps.
Mar 22, 2011 | Oster Microwave Ovens
The oster model OM1201E0VG model, is not getting any power so the food is not heating in addition the adjustment of the power level does not seem to be operating. Please advise
Hope that helps.
Jan 01, 2011 | Oster Microwave Ovens
Good luck.
Dec 26, 2009 | Oster Microwave Ovens
Simple instructions
Ask here, it seems they can get you every Oster manual as a PDF file. Maybe they have a more detailed version?
Aug 19, 2008 | Oster 0.7 Cu. Ft. Compact Microwave
Microwave Ovens Logo
471 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
