Question about Suunto D9 All-in-One Diving Digital Dial Unisex watch stainless steel012042300
I have new watch D9 and it is stuck in dive mode. I'm in Singapore so its humid so that might have started it off but how do i rest it? OR do i need to send it back to the shop? Thanks
Battery replace for Citizen Cyber Aqualand NX
My Cyber was working fine and reporting a full charge, but when diving, it would stop working and go into safe mode. I sent it in to Citizen and they replaced the cell, now all is good again.
Mar 06, 2013 | Citizen Promaster Cyber Aqualand Nx Dive...
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
My aqualung duplex alternates flashing seconds then "ER"in the lower display window, I've reset it as the manual instructs, after pushing the stem back in it beeps twice then starts the same...
This watch needs to be sent back to the factory to get the movement replaced. I am doing this for the second time in 4 years. Citizen Europe states it's a defective design. The watch goes into dive mode with sweat, humidity and washing your hands. The water sensor tells the computer it's gone diving but the pressure sensor isn't telling it the same thing which causes a fault with the computer. I was told to cover the water sensor with WAX by the factory repair facility. WAX on a $400 dive watch. Great. They shold have used the pressure sensor to initiate dive mode. Customer Service said it wasn't defective, so it was designed to need this part everytime the battery has to bre replace.
May 27, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
My watch is in Dive Mode, I am not diving, it will not return to normal time settings. Any thoughts?
I could not find any instructions for your watch but as it is described as a "multifunction" type, there should be a method of changing the function you are using. This is usually changed by pressing the "mode" button. Unfortunately, you watch does not seem to indicate which button this is, so you will need to experment to find out which one it is. It is frequently the one that is at the 8 O'clock position, so try that one first.
I see on the face of the watch are a number of indication labels which tell you which mode you are in. At the moment it should be indicating "dive". To change this press the mode button and the indication should step through the options till you reach the one you want.
Mar 07, 2011 | Sector Dive Master 3253967015 Watch for...
My citizen aqualand duplex watch has the word "chek" on the lower screen and it won't go away. What does this mean?
It turns to "chek" if the moisture sensor that triggers dive mode when you go in the water is exposed to water and you don't dive for more than an hour. The sensor is very easily triggered by sweat, so all you got to do is wipe the sensor between the crown and the upper right button with dry cloth and "chek" will go away.
Feb 21, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
Dec 11, 2009 | Seiko Divers SKXA35 Wrist Watch
Seiko M705 - 5A10 series divers watch. Time is Frozen
Have the batteries checked and an "AC" done to it. These watches generally have several batteries and the die off can be slow and only fail partially. The "AC" or all clear function will reset the circuit board and bring all your functions back.
As with any dive watch, be sure that you take it to a watch maker/technician that can reseal and pressure test the watch to insure it is safe for diving.
Sep 18, 2009 | Watches
The second hand is not moving
Got the same problem guys. i have one of the new electronic diving eco drives.
First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
Jan 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Suunto D9 All-in-One Diving Digital Dial Unisex watch stainless steel012042300 Logo
91 people viewed this question
Top Suunto Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
