Question about Sport & Outdoor - Others
I am missing the safety key off my Midas 818 Treadmill and would like to get a replacement safety key or would like to know how to get around using the safety key.
SOURCE: My sportcraft tx 2.5 treadmill does not have the safety key
any round magnet that will fit in the hole will work.
Posted on Dec 20, 2009
Testimonial: "Thanks a lot..This really helped"
SOURCE: I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Posted on Jan 10, 2010
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Posted on Feb 02, 2010
  • 42 Answers
SOURCE: Missing safety key. can you by pass and how? Not
hi the treadmill will not work without the key and you cant bypass it. if you go onto this website they are the main people who sell weslo treadmills based in leeds, ICON HEALTH & FITNESS LTD. or telephone 08451770512
Posted on Nov 13, 2010
SOURCE: I lost my safety key
I just found out I had lost my key too. I have a Merit 710T. I called the company and they directed me to their website.
http://store.horizonfitness.com/c-33-safety-keys.aspx
On the page there is a link to a chart which will tell you what key is right for your model. They are cheap, only @ $13. Not sure about S&H though. I've also heard that if the key is a magnet you MIGHT be able to use another magnet to complete the circuit. I'm going to try this when I get home to tide me over till I get my next check and order a new key.
Posted on Feb 04, 2011
How can I fix my treadmill as it won't run due to Safety Key Lock even when Safety Key is inserted?
Check here for guidance on how replace or repair your safety key:
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-safety-key/
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Apr 03, 2014 | Nautilus T514 Treadmill
Safety key
Jul 22, 2013 | Merit Fitness 725T Treadmill
Two lines appear on the console screen and incline starts going up, then when key is removed all lights go on but nothing works.
I assume you are talking about the safety key. It should have a string attached to it and a clip on the other end of the key's string.
The key is a safety feature and the key should be in the control panel and the clip attached to your shorts or shirt when you are using the treadmill. If you fall of the treadmill, the clip pulls the string and the key is pulled from the panel on the treadmill. This should stop the treadmill instantly by cutting main power to the unit. Main power is shut off because the key is a safety device and it MUST work every time. To help avoid design errors or unreliable stops when the key is pulled, a good designer will shut everything off, not just the motor for the tread belt. I would say your unit was designed by a good design team since everthing goes off when the key is pulled.
From my point of view, it is working as designed unless you are talking about a different key.
I know someone who did not wear their safety key and they slipped on the treadmill, the treadmill threw them into the wall behind the unit and they were stuck with their leg against the treadmill. The belt on the treadmill wore their skin down to the bone on their knee in only a few seconds. Lesson one, keep your treadmill at least 3 feet from the wall. Lesson 2, use the safety key and clip.
-Mark
Jul 17, 2011 | Reebok V 680 Treadmill
Im wondering if there is supposed to be a big magnet on my safety key for my eks treadmill because i went away for the weekend and had house sitters in and i returned to turn my treadmill on and its not...
Shannon-
Yes, EKS uses a magnet in the safety key for their treadmills. You may be able to find replacement magnet at your local hardware store. A dab of glue and you're all set. There are also a numerous online retailers that will sell a replacement EKS safety key. A google search will reveal a number of options.
Regards,
DIYpro
Apr 28, 2011 | Sport & Outdoor - Others
Missing safety key. can you by pass and how? Not sure which Weslo treadmill I have, bought used.
Nov 13, 2010 | Weslo Cadence CT 4.8 Treadmill
Stuck in safe mode
Error Code: Replace Safety Key (SAFE)
Meaning: Safety key is not recognize
Diagnostic: Replace safety key
If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
My Uncle gave me a Horizon T605 treadmill and the
horizon rct 7.6 , safety key off , replaced ,key.reed switch and board , still says safety key off ?? spoke to horizon several times and repair techs as well ,it can only be 1 of those 3 items , all switch & key tested good , must be a faulty new board ?? could it be anything else ??
May 28, 2010 | Exercise & Fitness
MISSING SAFTY KEY CAN YOU BY PASS TILL REPLACED
ive got given a 625 pro form treadmill and the key is missing i know i can order one but for now i just want to use it is there any way of bypassing the key so i can use it. thanks in advance
Oct 12, 2009 | Proform Quick Burn Pro Treadmill with 12...
Jan 29, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
110 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
