Question about Fisher and Paykel (IWL12)
F1 lights flashing not filling - Fisher and Paykel (IWL12)
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the lights flash is the machine beeping?If it is beeping are the lights that are flashing on the wash progress line?If they are starting from the left to right which lights are lit,is it the 1st and 5th or the 3rd and 6th etc.Please reply with additional information and i am sure I can help you.Looking forward to your reply.
Posted on May 22, 2011
ADP 4305. Where can I obtain a service manual?
Thanks for the detailed description of the symptoms that we should make it easier fault detection.
I conclude that there is a mistake F1 (1 x flash,1s pause,1 x flash).
Before anything, erase the failures by pushing the START button for longer than 1.5 second.
F1 - NTC break
Temperature out of the normal value (-3°C till +85°C)Temperature inside higher than +85°CNTC defectiveDishwasher is frozen, less than -3°C If temperature is less than -3°C, fill the appliance with a cup of warm water to warm it up before you start it. The failures F1 (NTC break) and F9 (continuous water inlet) are checked and indicated immediately after start program. Because that, too small quantity water is taked.
First, I suggest to measure the resistance of the NTC, which must be about 58,1 kOhm at temperature 20°C. Also, check wiring between NTC and board.
Dado
Oct 09, 2015 | Whirlpool Dishwashers
What does f1 mean when it flashes where the temp guage is?
It means you have a problem with the fuel injection system if you can start the bike then take it to a Suzuki mechanic. If the F1 is full on i.e.not flashing then the bike will not start normally. You still have a fuel system problem but now you have to find a way of getting it to a Suzuki mechanic. You should have a red light showing near the neutral indicator light.
Jul 14, 2014 | 2004 Suzuki GSX-R 600
F1 light flashing on my zx6r 2007
Have you replaced your exhurst system if you have did you put the O2 sensor back in as f1 error code is for this sensor and your CPU can not tell if the engine is running correctly and will shut the engine down when a gear is selected
Apr 06, 2014 | kawasaki ZX-6R Ninja Motorcycles
My kenmore elite washer, model #110.27092600 flashes an f1 error code when filling
F1 code = Primary Control Failure. Replace the machine/motor control assembly.
Call 1-800-659-7026. That machine has a recall for the control board and if your machine is in the recall they will fix it for free.
Jul 30, 2011 | Kenmore Washing Machines
While filling it will flash an F1 code and stop. If I cancel the cycle and press start again it will usually go ahead with that cycle until the nest fill up. What is an F1 code?
This is a pressure sensor issue on the machine control board .The only sure fix is to replace the machine control board which has been updated numerous times.( whirlpool is very aware of the problems) At one time whirlpool was assisting owners who had this concern .
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a 06 suzuki c90t,it will crank,then quits f1 light is flashing any help
the bike has efi.
if the f1 light is flashing then it looks as if a dealer is your next port of call as the fi would indicate a problem with the efi (electronic fuel injection) system
hope this helps.
Dec 24, 2009 | 2005 Suzuki Boulevard C90T
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Red warning light is on and f1 flashes were the temp shows 04gsxr
blinking red light means critical error check your oil if you have oil in the motor check the sensor on the oil pan! good luck! had the same problem wire was bear making contact at bottom near oil pan good luck!
Aug 29, 2009 | 2004 Suzuki GSX-R 600
Washing Machines Logo
130 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
