Question about Frigidaire Heating & Cooling
I have a frigidaire air conditioner window unit that has been working beautifully for about 8 months.... it has now stopped responding. I will unplug it to turn it off, plug it back in and it shows 0.5 in the display will be blowing full blast and eventually will go off on its own. Then it will turn itself back on.... ghostly :) What shall I do? I have a remote that has been lost. I am sure it will turn up soon but no matter how many time I press the buttons, the unit will not respond... please help ! - Thank you in advance - Dawn -
CompuGuy44
  • 432 Answers
SOURCE: Broken air conditioner?
Try another wall outlet. You may need an extenion cord.
Posted on Jun 25, 2007
  • 883 Answers
SOURCE: Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Posted on Jul 07, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
SOURCE: Haier Air conditioner does not turn on
encountered the same problem today. It would seem one of the buttons on the front panel membrane is stuck......play with the buttons till it loosens itself or use the remote if u have one....that worked for me
Posted on Jul 09, 2008
How do I fix heat on unit Frigidare Model LRA12HZT2?
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Dec 24, 2012 | Frigidaire FAH106N1 Wall/Window Air...
I turn off the a/c but the compressor don`t stop it continuing running the only way to stop the compressor is when I unplugged the unit, so can you help me to know what part need to be replace. thank you
The Master ON/OFF Switch either needs cleaning or replacing. I'd try cleaning it first with electrical contact cleaner. Be sure the ON/Off Switch is in the OFF position, before you unplug the unit, to take the face off to clean the switch & it's contacts.
Hope this helped you. Please let me know. Thanks.
Jun 11, 2011 | Frigidaire FAC126P1 wall/window Air...
My Frigidaire FAX050S7A window mount a/c unit recently stopped blowing cold air. The fan works fine and i can even hear the compressor turn on when i switch from fan to a/c. do these need recharged?
Yes they can leak and will need a recharge....just check first that the leak is very small or can be fixed before spending the money to recharge it...with the low cost of window A/C units you can easily get a repair bill for more then a new one would cost...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 21, 2010 | Frigidaire FAX050S7A Air Conditioner
I have a frigidaire window ac. THe compressor doesn't shut off. I have to unplug it for the compressor to stop. What could be the problem? Someone told me it could be the thermistor.
If it cools properly, it is not the thermistor. It most likely is the thermostat. Turn the knob to the warmest temperature and see if it shuts off. Still no? Then you can open up the control box. (DANGER--line voltage--can shock you) . Unplug the unit, open up the control box, take one of the wires(either one) off of the thermostat, tape it securely and isolated. If the compressor does not run now, then the thermostat is bad.
Jul 20, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire window air conditioner making buzzing noise
i would invest in a new unit the cost to get this one repaired will add up and theres no guarantee they will fix the problem
Aug 21, 2008 | Heating & Cooling
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
42 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
