Question about Breezaire WKL 4000 Wine Cooler
Display flashing 0.6 - Breezaire WKL 4000 Wine Cooler
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
THAT IS A BAD CONTROL BOARD ALLSO CALLED A SENTRY III BOARD, YOU CAN CONTACT THE MANUFACTURER 858-566-7473 AND PURCHASE A NEW REPLACEMENT BOARD ITS VERY SIMPLE TO INSTALL AND DOES NOT REQUIRE REMOVING YOUR UNIT.
Posted on Sep 16, 2011
Uniwell no 5400-01 0 flashing in display hard reset didn't fix
Haven't heard of a flashing 0 before but since the hard reset didn't fix it, I'd say faulty memory battery or stuck printer.
This company has service manuals which might help https://the-checkout-tech.com/manuals/cashregisters/Uniwell1.php
Jun 15, 2017 | Uniwell Retail Supplies
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Why is (0) flashing on screen
--0--
periodic flash on the display indicates re-zero required due to temperature change
Jul 30, 2014 | ZIPLEVEL PRO-2000 Precision Altimeter
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
Held the (0)down,nothing,then (#)nothing,then (*)nothing?What gives me the meter reading on a AL1655?
The total count will flash on the display in 3 digits sets. You need to have the copier ON & hold the "0" botton for a few seconds & it will flash the total count
May 29, 2010 | Office Equipment & Supplies
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
Blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the tallygenicom.com site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
Jul 27, 2007 | Tally Line Matrix T6100 Printer
Breezaire WKL 4000 Wine Cooler Logo
160 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
