Question about Microwave Ovens
Microwave so, if I find that the fuse is blown, can I simply replace the fuse and forget about the door switches?
  • Anonymous Nov 10, 2008
    I have a Goldstar MV1501 1000Watt microwave. There was a loud popping sound which tripped the breaker. I turned the breaker back on and the microwave was dead. Microwave was not in operation at the time. What could be wrong?
  • Microwave Ovens Master
  • 9,098 Answers
I looked at the previous "solution" to your first inquiry. Let's set that aside, shall we...
Generally, faulty door switches will cause it to either run but not heat, not start, or blow the fuse as the door is opened or closed.
You ran this in timer mode for a few minutes, then it died?
This is often a case that the oven was actually running (cooking) empty.
This will cause the magnetron to overheat, and its attached thermal cutout (or thermostat, depending on the model) to open.
If it's a good thermostat, it will cool down and come back on.
If it's a thermal cutout or bad thermostat, it will not come back on.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
The mini manual will show the location of the thermal cutouts / thermostats.
If this does not get you a FixYa, please reply back and update us with your situation.
Posted on Aug 18, 2008
Microwave will not work No Power, No clock nothing works
Remove the outer panel and check the fuse which is usually mounted near the power cord inlet.
Oct 19, 2016 | Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
Why does ge microwave blows fuse when door is opened?
Inspect the door switches and the wiring in the light bulb circuit. If the problem is a door switch, it will probably be visibly broken, or there will be burn marks on it. It's also possible that the door switch bracket is bent or broken and allows the terminals to short to the oven frame. Check the lamp socket - if it is cracked or burned, it should be replaced.
Also look for signs of arcing or burn marks on the controller board, especially near the relays (usually black plastic boxes about 1" x 1' x 3/4' mounted near the wire terminals or wire harness connector).
As a general note, it is rare for a fuse to fail by itself. If you find a blown fuse, look for a cause before replacing it. This may prevent wasting another fuse.
Jul 01, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating #mv1608bb
Open the back and look for a blown glass tube fuse. If the filament is broken, replace the fuse. If it's a solid fuse, do a continuity test. If you have continuity, then it is still good. Good luck!
Jan 17, 2014 | Goldstar Microwave Ovens
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
Over the stove microwave just stopped working. Circuit breaker was not tripped.
Sounds like the fuse is blown, you will have take the outer case off to find the fuse and replace it
Sep 07, 2009 | Microwave Ovens
Microwave wont run, displays E 10 on the screen and also microwave fault, press stop to acknowledge, just changed the door.
e 10 is the internal safety fuse has blown this often happens if door is altered for any reason moving the door can effect the setting of the monitor switches these are set to a high tolerance to avoid operation of microwave with door open changing the door has shifted these settings and blown the fuse, replacing the fuse may be enough to get it going but it should be checked for leakage.
Jun 11, 2009 | Neff H5470 Microwave Oven
Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Microwave Ovens Logo
175 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
