Question about Sanyo Heating & Cooling
Sanyo sap-k129eh air conditioner Operation light flashing no cooling
5 Suggested Answers
SOURCE: a continous blinking operation light and no indicator light
HAS THE UNIT EVER WORKED?
Posted on Oct 09, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
  • 334 Answers
SOURCE: All lights are flashing including Pre Def, Timer,
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
Posted on Jun 12, 2009
hvac1960
  • 2133 Answers
SOURCE: air con not working. Operation
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Posted on Dec 31, 2010
Sharp CRM-A750JBEZ
not blowing cool air
Jul 04, 2013 | Heating & Cooling
Sanyo sap-71a will not start using remote the remote will start other air conditioners thanks
Simple, remove power and then unplug DC wire from indoor display for 2 minutes.Again plug it, power on. And also remove batteries and re insert in remote and then use. If still problem, your signal receiving sensor defective. You have to repair/replace indoor PCB.
Feb 05, 2011 | Sanyo 12KHS71 Split System Air Conditioner
Hello, I have a split system air conditioner (one of SAP-K181AA or SAP-K241AA or SAP-K251AA) and it is dripping cold water inside onto the floor. Can you help.
try to unclog drain line of your ac.or check the elevation of you indoor may be the drain water cannot flow smothly.
Jan 30, 2011 | Sanyo Heating & Cooling
Have purchased premises with a sanyo sap-k302ah split system air conditioner and the previous tenant cannot locate instruction book on how to operate can you help me out with one please Maxine
There you go
http://service.airwell.com.au/airwellsanyoparts/Website 2007 update/sanyo/SAP-C302AH/sm700568-00_11 service manual.pdf
If you cannot veiw please let me know and i will re post the link or email it to you
thanks for using fixya
Apr 22, 2009 | Heating & Cooling
Heating & Cooling Logo
240 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
