The power noise will come but you can't see or hear anything.
  • joytthasavag May 22, 2011
    This is with my samsung tv.
  • Computers & ... Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
if this fails to fix the problem
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Posted on May 22, 2011
  • 1 more comment
  • Brian Sullivan
    Brian Sullivan May 22, 2011
    sorry my mistake although it was listed as problem with motherboards
    I know, that was my mistake. I'm new too this :/
  • Brian Sullivan
    well this could be reference if you get a computer?!
1998 Saturn SL1 SOHC loss of power going up hill.
Sounds like you have a failing transmission to this 35 year repair technician. Have you even run the fault codes with a scan tool?
Mar 01, 2017 | 1996 Saturn SL
I drove my car to work this morning and then to my house about a mile for lunch after lunch my car wouldn't start and i hear one tick noise near the power distributor... my battery is fine and eve
Starter solenoid or just a starter bad, sometimes this comes out of nowhere but usually you can hear it start cranking slow shortly before failure.
Oct 10, 2012 | 1999 Mercury Mountaineer
Have the STX Vipor electric car. Fully charged but won't go, just hear clicking noise.
If this was a real car this could be anything from anti-theft to a blown battery. Being as its a power wheels it would probably be the battery is ruined because it was charged sitting on concrete bare. Which will quickly destroy a battery. You may have to buy a new battery. The only other thing I can think of to check is if the motor is ruined powering the wheels. Which will be a much more expensive fix. Hope this helps:)
Sep 20, 2012 | Fisher Price Power Wheels Rechargeable...
So my 2000 Pontiac Sunfire has an issue with the power steering. I'm not sure if its a belt, the pullly or barrings in the pully, or if its the actual pump. It has fluid and everything. But you can...
Firs check the belt tension, you should have about 1/4 of an inch free play in the belt, that is up and down movement of the belt, also check the fluid level.
Is there any noises from the powersteering pump, like a bubbling noise or a whirring noise?
Jul 25, 2011 | 2000 Pontiac Sunfire
Can not get static out of radio i have a cobra 29 with weather channel the squ knob seem 2 b not working sometimes can u help me
Turn the squelch down, and the RF gain all the way up.
You need to realize that some times, there is not a lot of noise out there. Right now lately there has been due to skip. But it does die down. When you hear a lot of noise for a while, then it goes away, it messes with your head. You don't hear anything, but that's because its quite out. I would test it by talking to some one on the radio. If you can hear them just fine even though you don't hear a lot of static, then its just quiet out.
Jul 23, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
My hard has all of sudden is not being picked up by my pc or anything for that matter. The power light is flashing on it so I'm thinking it might be the power supply. What do you think ?
Sometimes it could be that it's not registering the letter for the drive. If you hear a chime when you plug it into the computer and turn it on, it is being recognized by your system.
If that is the case. Right-click on your "My Computer" icon, and click on Manage. Then go to "Disk Management". There, it will list your hard drive. You can distinguish it from your computer's hard drive by the size, and normally your computer's hard drive is set to Drive 0 by default.
Once you identify it, you can right-click and "Assign Letter Drive" and that should fix it.
If it does not chime (first make sure that the sound is on). You can try and see if there is a clicking, or a whirling noise. A whirling noise is a good sign. A clicking noise is not. If you hear nothing, then something between the connector to the hard drive inside is bad or the cord connecting the drive to the computer is bad. If you narrow this down, you can normally get the right cause.
I hope this helps.
Please Rate
Jul 08, 2011 | Western Digital Wd Elements Se 1tb...
Dishwasher is not draining. Wet-vac'd all water out cleaned filters still does not want to drain. Less than 2 years old.
The pump has gone bad or the drain hose is plugged, or the pump is OK but has gook (technical term) in the impeller. check the drain hose when the washer is supposed to be pumping out. Also listen for a noise. Does the pump sound like it's running? can you hear any water noises? does anything at all come out of the drain line (you may be able to see this by shining a flashlight done the drain it's hook to) If there is no noise the pump my be out or perhaps a connection came loose. Make sure you turn power off at the breaker panel before poking around underneath it, just not having it on is not enough there will still be live power to it. You might just try putting more water in and aggressively sucking water out with the shop vac in hopes of undoing a clog. Hope this helps
Jun 11, 2011 | Dishwashers
My panasonic cordless phone model # KX-TG2258S the handset works but when you dial or talk or even just pick up the phone you don't hear any noise at all. not dial tone but it does call out. you just...
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
May 06, 2011 | Panasonic 2.4GHz Digital Cordless...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
