Question about Amana ABB1921DEW (185 cu ft) Bottom Freezer Refrigerator
Someone left the freezer door open all day and now thats its closed nothing is freezing and I noticed the compressor is not kicking back on - just the fan is running.
    Problem Solver:
  • 6 Answers
Hey, it is possible compressor has been overloaded due to constant running, you could get access to it and have a look on the motor, all motors have overload protection, sometimes it can be a small button on the motor frame near where the power cable comes into it. It may even be located inside the terminal block for motor electrical connection. When attempting to fix anything electrical, you MUST ALWAYS unplug it and make sure it is dead.. Hope this may help. Matt.
Posted on May 22, 2011
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
Cooler Compressor runs but cooler won't get cold?
If the compressor kicks in then check the lines to see if they are cold. It is possible the compressor burnt out from leaving the door open. Purchase a sensor alarm to alert you if the door is left open.
Nov 16, 2013 | Coldtech S3BRR-18S Commercial Refrigerator
Freezer door left open will it work again?
yes it must be shut off and completely defrosted.with doors left open it usually takes about 2 days. what happened if you look at the back wall in the freezer from the inside you will see a bunch of ice and there is more behind that panel you are looking at. it froze up the coils so that no air will get through them. good luck rich
Sep 18, 2012 | GE 20.3 cu. ft. / 575 liter Upright...
Someone left the door open on the freezer and all the meat went to waste. The problem I'm having is the freezer only gets cold and will not freeze anything? I have no Manuel, and the unit is only...
Same thing happened to me, turns out the compressor when bad at the same time the door was left open, it was pure coincidentally, had nothing to do with the door being left open.
Jan 29, 2011 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer door was accidently left open for about three hours -- now the top compartment and the freezer are warm -- everything has defrosted -- and nothing will re-freeze -- ice can not be made -- strange...
Switch off the unit at the wall and leave it for a day to cool off. I think your compressor has overheated and has cut out on thermal overload. There should not be any problem with leaving the door open. The problem with the compressor is likely caused by poor power supply or a power surge.
Mar 09, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Whirlpool model ED25TW intermittent freezing
HI. it looks to me like a failing fan motor . it stops sometimes, then you close the door, and it goes. or could be hitting ice. remove the back panel ov the freezer, and check the fan motor
Oct 15, 2008 | Whirlpool Refrigerators
Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Dec 08, 2007 | GE GSS25SGSSS Stainless Steel Side by Side...
Freezer/Fridge work SOMETIMES
Sounds like you have a bad relay on the compressor or a bad compressor. If the compressor is a Tecumpseh brand then it is most likely the problem.
Oct 04, 2007 | Jenn-Air JCD2290HES Side by Side...
Amana ABB1921DEW (185 cu ft) Bottom Freezer Refrigerator Logo
147 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
