Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
26 hp briggs only runs with chock out, why - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My 15 hp briggs and Stratton engine won't run smoothly with the fuel shut off open. I have to nearly shut off the valve for it to run smoothly. Any suggestion?
I would have a look at the choke. Chock on = reduced air flow = rich (lots of gas vs. air) so if you reduce the fuel by restricting with the valve, it more closely matches the air.
Feb 05, 2015 | Miscellaneous
How much should a 26 hp briggs charge
16.5 to17 is way too much! change voltage regulator.
Apr 03, 2013 | Garden
Only runs with chock on
sounds like a dirty jet inside the carb
Jun 08, 2012 | Yard Machines 155 Torque Briggs Stratton...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
117 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
