Sony Ericsson K750i Cellular Phone Logo
Posted on Aug 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Regarding how to get simcard out from the mobile set
I m trying since 1/2 an hour to get sim card out ot set it in another mobile
Jalal Sordo
Level 3:
  • Master 1,800 Answers
  • Posted on Aug 15, 2008
Jalal Sordo
Master
Level 3:
Answers
1800
Questions
Helped
590050
Points
5194
Move it a lil bit up then pull it out its will not broke i mean the sim card
Insert sim
What is your mobile model?To insert simcard,the following conditions should be satisfied....
1)The mobile should be unlocked to accept the sim card
2)The mobile should have the sim slot (most CDMA phones do not have that provision)
3)The simcard size should be supported by mobile phone.
Now,if your mobile is locked with a particular network then you need to unlock it.For that you can either approach the respective network provider or third party unlocking services like Simpleunlocking.com or unBBlock.com (This is specifically for Blackberry phones) and unlock your mobile.Once your mobile is unlocked the sim slot will either be in the side or above or below the battery depending on your mobile model.If you search in Google you probably will get a more clear idea about where your sim slot is located.Once you find the sim slot remove the sim card and note down the position; replace it with the old sim card(it should support the phone sim size specification).
Jul 12, 2013 • Cell Phones
15helpful
4answers
Hw to get network key to unlock alcatel ot708
Hello
You can unlock phone here
http://sim-unlock.net/sim-lock/3/Unlock_by_code_for_Alcatel_phones/
Aug 06, 2011 • Cell Phones
1helpful
2answers
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
1helpful
3answers
I want to unlock my Alcatel Mobile phone, model: OT-209?
HERE'S THE ANSWER TO YOUR PROBLEM:
How To Unlock Alcatel Phones1. Power on the Alcatel mobile phone without the SIM Card in
2. Type: *#0000*CODE#
3. Finally, type: *#0001*CODE#
(Where CODE = your Alcatel unlock code)
4. Or, you can visit this site for an instruction: http://hyfeno.com/unlock-alcatel-mobile-phone/
Now you should have yourself a fully unlocked Alcatel mobile phone. You can use it on any other phone carrier now, enjoy.
Your problem is solved. Thanks...
Hello sir,i m having some problem with my x3 nokia mobile...though sim card is present it is been not detected ,on my mobs screen we can see..."NO SIMCARD INSERTED"..hope u will help me.... ...
Just check your SIM for malfunction. If you have spare SIM you suggested to try in your phone ( just to where is the problem lies). If other good SIM still not readable, you problem with phone ( it probably on your SIM card port / interface). It will need repairing on shop.
Regards
Dec 20, 2010 • Cell Phones
2answers
Simm card not recognized
You need to isolate the problem. Try the following:
1. Use a working SIM card into the problem phone. Make sure that it's from the same wireless provider.
2. Try your SIM card into another phone.
Doing this will allow you to isolate the problem.
Sim card or sim card slot problem
up the all legs of Sim tray with screw driver
4helpful
2answers
No simcard eventhough simcard inserted in MOTOROLA ROCKER E6
first remove the sim card and then switch on the phone... then choose antenna on... after a few seconds you will see emergancy only on your screen ... turn off your mobile and insert the sim and switch it on again ... this solved my problem ... but this is not working on my cell now.. does anybody have a solution?
Problem regarding mobile sim card chang
Your phone is asking for a code because it is locked to only work with one phone company. If your new sim is from a different company, you can request the unlock code from your old company, they may or may not give it to you (tmobile usually does, ATT/Cingular usually doesn't). The other option is to use a unlocking service, you can find plenty on ebay. If you didn't change phone companies, your new sim card is most likely bad, have your phone company send you another one.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
