Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor drain battery and wont start.i put new battery same thing
    President:
  • 3,074 Answers
The magneto is made of 2 parts one magnet is mounted on the flywheel the other is on the motor close to the flywheel,I have never seen one go bad as they are permanent magnets,your problem is either the fuse a bad connection or broken wire. Follow the wire from the fuse and make sure all connections are good if they are post back here and we will find the problem. Hope this helped Tim
Posted on May 22, 2011
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine wont turn over. too much compression. ehaust valve is opening. new starter and battery.take out plug and it will start. put back in , nothing
jtd ride on mower wont start will turn over a little but if i take the sparkplug out it will turn over no problem any ideas please
Jun 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Wont start
Your battery is junk. Replace it.
Lead/acid batteries lose about 1% of their charge per day, so in 90 days of non-charging they are basically discharged. This is a bad thing. When winter comes, put a smart trickle charger on it, or at least once a month put a non-smart trickle charger on it for a couple hours or an afternoon so you keep it charged up.
I love/hate batteries.
Apr 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
104 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
