Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
I can't connect internet although i have a driver for it
  • Gigabyte Master
  • 27,725 Answers
First you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you already have the internet
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Posted on May 22, 2011
Although my router is working and I'm connected to
Make sure your wireless Adapter is on, my laptop has a switch on the front that turns it on and off. Also you can to to Control Panel/Network And Internet/Network Connections. Make sure your wireless Adapter is turned on in that menu. Happens to me all the time :)
Apr 18, 2013 | Computers & Internet
I have a laptop hp compaq 2230s, which does not want to connet to the internet. the message is saying that i have only a local area connection and therefore does not receive data from the net, even when...
For Windows XP you may re-install chipset driver, wrong driver may cause ethernet driver missed driver too
2006-03-24 , Version:7.2.2.1006 A, 1.07M <<< Chipset compaq presario v6000t ( Intel ICH7 ).
For Windows Vista : open device manager >>> update driver chipset > via internet or you can ask for the driver by personal.
Aug 15, 2011 | HP Compaq Presario V6000T Notebook
I try make wifi my router from xfinity but i cant
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online. However, if it doesn't get you connected, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might have more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
All the best
Ben
Jul 03, 2011 | Computers & Internet
I can't get a connection
?? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this. ?? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database. ?? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz. ?? Open Internet Explorer; ?? Click on 'Tools'; ?? Click on 'Internet Options'; ?? Click on 'Connections'; ?? Click on 'Setup' ?? Click on 'I want to set up my Internet connections manually . . .'; ?? Click on 'Next'; ?? Click on 'I connect through a local area network (LAN); ?? Clock on 'Next' ?? Click on 'Next' [This is not an error]; ?? Click on 'No'; ?? Click on 'Next'; ?? Click on 'To connect to the Internet immediately . . .; and, ?? Click on 'Finish'.
Clicking the Start button Picture of the Start button • Click on Control Panel. • In the search box, type network, • Click "Network and Sharing Center" • Click Set up a new connection or network • Then double-click "Connect to the Internet".
All the best
Ben
Jun 28, 2011 | Sylvania G-Netbook
My ps3 will not let me get on line.it said i don't have a ip address
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
That should have you online. However, if it doesn't get you online, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
All the best
Ben
Jun 25, 2011 | Belkin (F5D7230-4) Router (587009)
My network connection seen in my system but internet not open, why its coming, any setting changed or?, pls help me . last night upto 9pm i am used network,
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
All the best
Ben
Jun 21, 2011 | Computers & Internet
I have a Belkin F5D8236-4 Router. I have two laptops but one is connected with RJ-45 and not wireless, the other one is connected wireless. I wanted to share files using this router. But I cannot find one...
Begin by turning on your computers and your router
? Make sure that you are using the latest drivers. You can download the latest driver/firmware from Driver Downloads Database.user.name.xadsl@xtra.co.nz.
? Open Internet Explorer on the computer that you cannot see;
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
All the best
Ben
Jun 18, 2011 | Computers & Internet
My laptop has had a complete memory boot and i can not get my wireless connection back on. How do i correct this problem/ i am using a ethernet cable at the moment to get connection to internet. Thank you
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
All the best
Ben
Jun 18, 2011 | Acer Aspire 5315 Notebook
No internet connection
re-install all network drivers or uninstall all network drivers and install again the drivers
Apr 05, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
76 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
