Question about Home
My caroma stylus dual flush has a hissing sound and water keep on flowing off the valve. What shall I do, this flush system was just repaired 12 months ago as part of the warranty now it is coming back again.
  • 659 Answers
SOURCE: Champion4 leaks water through flush valve
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
Posted on Apr 08, 2009
  • 80 Answers
SOURCE: descaled machine, clean solenoid valve. now steam is coming
try replaced gasket in high pressure valve.
Posted on Aug 27, 2009
Testimonial: "this person is soooo helpful. It has been amazing to learn."
  • 5225 Answers
SOURCE: The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Posted on Feb 19, 2010
  • 12744 Answers
SOURCE: Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Posted on Mar 02, 2010
bloues
  • 56 Answers
SOURCE: I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Posted on Jul 12, 2010
Caroma toilets repair
have to know whether you mean water is flowing into the bowl?, or "over-filling" the tank? Could either be a bad flapper(More common), or the "fill-valve" is leaking.
Aug 24, 2014 | Home
Water leaks from tank to bowl all the time
It is most likely the flush valve gasket. This is the equivalent of a flapper on a normal toilet. You can purchase these seals at plumbingmall.com 750017 Outlet Valve Seal for M5 Flush Valve
Aug 06, 2013 | Caroma Sydney Smart 270 Elongated Dual...
Despite fitting a new washer kit to an old style caroma dual flush/float system stop valve..water is still seeping into tank....even if i plug the inlet nozzle with my finger which yu would think would be...
I suppose you're talking about a toilet. One likely issue is the flapper valve ( if this has one). If no flapper then check whatever sealing mechanism is used to prevent water from entering the bowl when idle. Clean the sealing surfaces good. Make certain they are properly aligned.
Sep 01, 2017 | Caroma 270W-RF Reflection Round Front...
Hi there we have a caroma slimline toliet 2000+ that hisses constantly after you've flushed and the system fills up with water.even when its full it still hisses we have replaced the ballcock and the...
this is usually caused by slightly higher than normal water pressure in your area or foreign matter lodged in the fill valve body. the quickest/cheapest solution is to flush the toilet and turn down the pressure to the toilet by slowly turning the shut off valve toward the off position till it stops making noise. otherwise you could replace the fill valve w/a "whisper" valve by fluidmaster, from home depot,lowes,etc, which is much less noisy in general but even a whisper will make noise if the water pressure is to high. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Home
I have an old Caroma Dual flush ( 15-20 years) and the washers on the inlet valve dont seem to be able to regualate the flow in, after the toilet has been flushed, as a result water sprays up out of the...
Plz rate my advice
Jun 16, 2010 | Caroma 270W-RF Reflection Round Front...
I have a 1998 Caroma Reflections cistern p/n 6871774. It is making a hissing noise after the tank is refilled, and water streaks down from the supply rim of the bowl. Which part needs to be replaced?
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Jan 10, 2010 | Caroma 270W-RF Reflection Round Front...
Home Logo
169 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
