Question about Frigidaire FEF366 Electric Kitchen Range
What size circuit breaker for stove? - Frigidaire FEF366 Electric Kitchen Range
  • Frigidaire Master
  • 2,605 Answers
Hello, Welcome to FixYa. For a eletric range either 208vac or 240vac requirement is a 40amp circuit breaker. For a gas range a 15amp circuit will suffice. Hope that answers your question. Thank you for choosing FixYa and please take a moment to rate the assistance I provided for you. Regards, Macmarkus :)
Posted on May 22, 2011
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Oven stopped working
If you are saying that the breaker in the breaker box has been tripped, then there is a problem with the circuit or in the stove. The circuit may be checked with a volt meter. If the problem is in the wiring circuit, the breaker will trip with the stove unplugged. The problem is most likely in the stove, and the stove's wiring needs to checked. If you are unfamiliar with 230V wiring and how to safely test the wiring, have an appliance technician service the stove.
Apr 15, 2014 | Ovens
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-install-a-subpanel.html
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
Nov 04, 2012 | Bryant Westinghouse Bqc Quad Circuit...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Maytag stove mer6769baq trips the breaker whenever plugged in
It sounds to me like there is a short circuit either in the plug or the connections at the stove. It could also be within the stove although that seems very unlikely. If this happens when your using the stove, the breaker and circuit could be undersized (required breaker size-50AMPS) Check all wires and the breaker.
Apr 01, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Circuit breaker goes off while self cleaning
self cleaning uses above normal cooking temps
check how many amps your stove is rated for -40 amps ?
see what size breaker you have 30amp ?
call electrician
hope this helps
Mar 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Mar 11, 2009 | Napoleon Auburn Pellet Stove Heater
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
337 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
