Question about Pacific International Pacific Evolution 24 Inch Girl's Mountain Bike
How do you adjust the chain on the girls 24" evolution?We just gave my daughter the bike and the chain keeps falling off.
    Brigadier General:
  • 8,546 Answers
Upland dragonfly 16 inch girls bike. Pops put it together for my daughter birthday gift. Notice daughter having trouble pedaling. I inspected by pedal by hand, with rear wheel off ground. Found it is...
the tire is pulled back too hard against the chain. Loosen the rear wheel nuts and re tighten them make sure there is no slack in the chain, and make sure the wheel is centered by checking the gap between the tire and the chainstay(rear part of frame, looks like a triangle)
Mar 23, 2015 | Cycling
I have a problem. With my chain every time I put it on my scooter it keeps on falling off when I ride it.
You need to adjust the bike to the chain. That is why there are chain adjusters on the swinging arm.
Oct 10, 2013 | Motorcycles
125cc dirt bike chain keeps falling off when i change gears???? why is this happening and how can i resolve the problem.....please
Here's a video Martin Frereault suggested as a solution to your problem from YouTube:
How To Adjust Your Motorcycle Chain
Apr 28, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
CHAIN KEEPS FALLING OFF ROADMASTER 26 " MEN'S BIKE
As "roadmaster' doesn't really narrow it down much perhaps a generic web search for "chain falls off bike" would work for you. YOU can see your bike. We can't even tell if its a single- or multi-speed.
Sep 22, 2011 | Cycling
The gear shifter on the Girls' Diamondback Tess 24 is too tight for my daughter to shift gears. She can shift down toward the higher numbers, but getting back up to 3-2-1 is nearly impossible for her....
hi.
these can be adjusted, but the first thing to do is to change the entire gear cable.
spraying the whole thing with wd40 or simillar may help, but the lining of the outer cable has almost certainly worn and is causing the problem you are having.
this is very common. bike makers tend to use relatively cheap cables, and they can wear and cause problems quite easily.
oil the new cable before you fit it and you should not have any more problems.
hope this helps
Jul 07, 2011 | Diamondback Tess 24 Mountain Bike Girls' ...
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
My daughters Princess bike won't work. We were putting on training wheels but when I reassembled it the back tire would stay still and the chain would fall off. I think I am missing parts, but I am not...
hello. It sounds like you simply have to loosen the nuts holding the rear tire into it's frame slot and slide that tire back further until the chain is snug, not tight. Then retighten the nuts and you should be all set.
Sep 18, 2009 | Huffy 16 in. Girls Disney Princess Single...
Pacific International Pacific Evolution 24 Inch Girl's Mountain Bike Logo
167 people viewed this question
Top Pacific International Cycling Experts
Michial Gueffroy
Nathan
dante
Are you a Pacific International Cycling Expert? Answer questions, earn points and help others
