Question about Whirlpool Refrigerators
I seem to be losing refrigerant gas in the system. How does one go about fixing or finding the problem with in the system? Whirlpool Model # ELZATRRMS007-LO Puchased 2004
  • Whirlpool Master
  • 2,699 Answers
The money it would cost to have someone come in,find the leak and fix it would be almost as much as a new machine.don't waist your money.you need all special tools to do this and sometimes you can't find the leak because it leaks internally inside the frame so like i said,it's 7 years old just replace it with a new machine
Posted on May 22, 2011
  • Sal De May 22, 2011
    the model number you sent isn't correct.one way to tell if the fridge is low on freon is to remove the inside back wall of the freezer,look at the evap coil,if the frost pattern isn't even then you'll know you have a leak,usually the frost will be just on the line and not even on the coil or very little of the coil frosting up.hope this helps,
Which gas are refill in 210 whirlpool fridge
Hello Arushdeep Singh,
I have tried to find a "210" whirlpool,..
Sadly only finding some vague references to a
17 cubic foot OLD TIME refrigerator... (?).
The good news: If indeed you are speaking of
an "OLD TIME" unit more than 3o years ago
your gas is Freon R22...
The bad news is that is BANNED and your
choices are varied... interesting and all fairly
expensive.... (hideously expensive).
Sorry that is all I can relate on a MODEL 210.
(Lot of R22 scams going on out there... be careful).
((of course)).
30 pound canisters sell for under $800 US Dollars.
R22 FREON REFRIGERANT 15 oz CAN UNUSED eBay
May 14, 2017 | Whirlpool Refrigerators
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
How do I refill the refrigerant in my fridge
how do you know it is short? In most countries it is against the law to just refill the refrigerant you have to find the leak and fix it make sure it holds pressure then u can weigh the exact amount into it. You also have to Vac out the system before adding referigerant and also change the filter dryer if the system did indeed go short of gas
May 23, 2014 | Whirlpool GC5SHEXNS Side by Side...
Our 2-year old Whirlpool side by side refrigerator is not cooling. Cooling power seems to have been reduced over a couple of days as it didn't die suddenly. Initially the compressor wasn't going. A...
ONLY THING I CAN TELL YOU NOW IS THERE IS A LEAK SOME WHERE IN THE SYSTEM. AND I M SURE THE NEVR DID ANY LEAK CHECK ON THE SYSTEM IF YOU DO NOT WANT TONGET AN OTHER REFRIGERATOR; TRY GET A REPAIREMAN WITH EXPERIENCE AND HAVE GOOD TESTER EQUIPMENTS
Oct 24, 2010 | Whirlpool ED5FHEXMQ Side by Side...
My whirlpool gold side by side serial # slo539783 model #gd
Sound like you have a refrigerant leak I suggest to take it to a pro because you need lots of tools and knowledge to properly fix it And don?t let people tell you than is just to add refrigerant because that is a common myth or miss conception, refrigerant don?t ware out or burn out if the system need refrigerant is because there is a leak some where.
Jun 07, 2009 | Whirlpool Refrigerators
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
May 09, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool repair service in Abu Dhabi
you probably found the only place that you can get help. but you could call whirlpool at 800 253 1301 and see if they do have someone they can recommend to help.
why not just ask what you need help here and that way you could fix the problem yourself.
try us here and see if we can help.
thanks tzweeb
Feb 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
