Question about Dryers
Banging sound on eacvh rotation, looks off center, even with nothing in it.
    President:
  • 3,074 Answers
Drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on May 22, 2011
Kelvenator split system air con has a loud banging noise from outside. I think it may b the fan as it's banging on something. How do I fix it
Start the air conditioner and physically go and have a look. You should be able to see and hear what is causing the problem. If it is the fan, assuming there is nothing caught, then something has changed to cause the 'Banging' sound. Either the cowling has moved or a fan bearing has collapsed etc. Once the cause has been found, then that's another question on how to fix. Cheers.
Dec 14, 2016 | Heating & Cooling
When it rotates it gives metal banging sound what is the reason?
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Tumble dryer dose not rotate
Sounds terminal.
If any bearing becomes too siff to rotate then the may be consequences for the drive, (i.e. perhaps the motor has burnt out).
If there are signs of extreme wear, then perhaps it is time to replace it.
Dec 14, 2009 | Dryers
Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Jul 06, 2009 | Washing Machines
Banging Sound from Rear of 2001 Explorer
check your sway bar link pins they probably are broken in the back .
Apr 16, 2009 | 2001 Ford Explorer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Samsung J1045 Front Loading Washing Machine Loud Banging Noise
Throw it off a cliff. I have the same model and have had so many problems. Don't even bother calling customer service, they won't help. Cut your losses and buy a new machine
Mar 06, 2008 | Washing Machines
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
