Question about Samsung BN59-00856A Remote Control
The FAVCH button on our samsung remote control (bn59-00856a) has come off the unit. It doesn't appear to be broken (there is a round piece in the center). Before coming off the unit this button would appear to stick and whenI put it back in the unit it does stick> In fact, sometimes it changes multiple channels even when not pressing the button. Is there a way to repair this without replacing the entire remote control unit? Note that this particular button gets significant use as we use this to change channels.
SOURCE: Samsung remote control problem
Same issue as lisawrob
Check to see if there is another remote with something sitting on top of it. I had the same problem and found another remote transmitting (continously).
Posted on Aug 10, 2008
bernardlunda
  • 318 Answers
SOURCE: My samsung tv is not responding to my remote control
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Posted on Mar 27, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
Stevenslav
  • 65 Answers
SOURCE: can't change channels. don't have remote. need to get channel 3 for cable
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
Posted on May 21, 2009
SOURCE: Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
I have 2 LG tvs next to each other, and I used pieces of transparent sheet of plastic with polarizer on the tv IR receiver AND the remote. if you just put the sheets on the receiver, it won't work. The trick here is that when both sheets are in the same space (both vertical or both horizontal) the signal will get through, if they are not (i.e. one vertical and the other horizontal) light (or IR wave) won't pass, ergo, it won't get to one of the devices. you have to put one of the tv polarizer sheets rotated 90 degrees (or one vertical and one horizontal), that way, when you tilt your remote (pointing the tv, but rotated 90 degrees), it will control one tv, and in normal position (pointing the tv and rotated 0 degrees) it will control the other TV. of course, this works if you have nothing between the remote and the tv; if you have a repeater, I don't know what will happen, but I think it won't work (except of course if you do the same thing of putting the plastic sheet in the repeater). You can find plastic sheets from cell phone screens, old calculators, clocks, etc. If this thing doesn't work, it means that your polarizer is not good, and you need to find another one. Hope I had helped a tiny bit :)
Posted on Mar 13, 2010
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
Channel selector doesn't work
If only 1 button does not work it may be a problem where some liquid got inside--
Some units have a lockout feature which will disable most or all buttons on the remote and or the set.
If set changes channels with the buttons on the set problem is with the remote--they can be tested easily.
Apr 15, 2012 | Samsung Bn59-00996a Remote Control
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
It does no obey to any commands other than lighting up with the letters (RC1)
RC 1 or DVD 1 is the unit's default remote command mode. You can try the following with the remote:
While the unit is on, pick up the remote, then press and hold [ ENTER/OK ] and the number [ 1 ] button together for 5 - 10 seconds, then release. Repeat the procedure if it makes no difference and the unit still ignores the remote. If it doesn't work, try new batteries, then repeat the above.
{ You can reset the unit if necessary (press and hold [ CH UP ] and [ CH DOWN ] button together for 5 - 10 seconds on the front panel (not the remote), until 'SETUP' appears in the display). }
Hopefully this should help a bit. You should not need to continuously reset either the main unit or the remote.
May 13, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I would like to operate a Samsung HD Cable receiver (DCB-H360R) by means of a Yamaha remote control (RAV293). I have tried all Samsung remote control codes as specifid in the Yamaha Owner Manual, but no...
Yamaha remote supports only those codes that are in the manual (they are pre-programmed in the remote), so no other code can be used. Your only option is to try codes from different brand in the manual (if not done already) or buy a universal remote, which you can program both for Samsung and Yamaha.
Nov 28, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Samsung BN59-00856A Remote Control Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
