Question about Garden
My Husqvarna LTH1342 Riding mower I just purchase was a champ mowing my grass 3 times with no problem. My son used it on his lawn, finished it and now it does not want to move forward or backwards. Did the belt possibley come off the pulley? How do I access to make sure. Appreciate your ideas before I take into a shop.
  • Roy Cagle
    Roy Cagle May 22, 2011
    Can you check the action of the shift lever and linkage to the transaxle to make sure it is not clogged with debris or possibly binding. Lower the mowing deck all the way and get on the ground to inspect the shift linkage and connection to the transmission.
    President:
  • 3,074 Answers
Http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CHUS%5Cimages%5C90%5C35%5C0019.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=23
Posted on May 22, 2011
  • 776 Answers
Near the rear tranmission, the belt is essentially under the seat area. You will have to get way under to see it. In the front, it is under the center of the engine. The chassis of the tractor hides this belt very well. Don't get it confused with the belts that drive the mower deck.
Good luck,
-Mark
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do you remove the bolts on the mandrel cover of the mowing deck. The bolts begin to loosen but then seem to get tight again.
I would keep turning them, there may be old grass, dirt, etc. that's making them turn harder. If not look underneath deck to make sure theres no nuts on bolts.
Aug 09, 2013 | Husqvarna YTH26V54 54"" Riding Lawn Mower...
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Apr 09, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Deck will not shed the grass . the grass has to be cleaned after each mowing, lawn is not mowed when wet,
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
Apr 04, 2010 | Husqvarna Garden
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
