Question about Samsung Refrigerators
My Samsung SRS614DW started randomly beeping at 3am this morning. Upon inspection the fridge door open indicator would come on along with a beep, however the door was well and truely closed. I've looking in the owners manual for any ideas but none found. The fridge is still nice and cool showing 2 degrees C, freezer up to -13 (set at -20) but prob more my fault as I had door open a bit. When the beeps occur the right hand fridge door symbol lights up and the temp display goes to random numbers. I've seen 0, 1, -1, 6, 7 so far. Then it stops for anywhere from 2 secs to many minutes then repeats. Please call to discuss. Fridge would be approx 8 years old Cheers
  • 19 Answers
SOURCE: I have an LG Fridge
May have an earth problem, have a refrigeration technician check the earth terminal in the back of power point and back of refrigerator, also check the connections of plugs to the printed circuit board (PCB) in the fridge.
Posted on Nov 13, 2008
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
diodeic
  • 1622 Answers
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Posted on Aug 15, 2010
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
our problem was fridge door alarm ,no cooling ,light out ,Freezer ok. Turned out to be the fridge side of the fridge/freezer door switch . Removing the double switch (it's a press fit) enables the fridge fan to work while waiting replacement. Replaced with new double switch now we have a light too.
Posted on Jan 10, 2011
ginko
  • 19396 Answers
SOURCE: Fridge sat turned off for
Hi.
Try disconnecting power cord for ten minutes (turning off is not enough). See if that does reset the fridge.
If that does not help, then check if there is ice forming in evaporator coil at the back of the fridge. Eventually wait one or two extra day. If ice starts forming and fridge quits cooling, then you have a problem with the defrost system. Likely the thermostat or the defrost timer.
IF the unit keeps cooling regularly, and defrost is OK, then it may be a disconnected temperature sensor. This will cause beeping, and fridge cooling regularly.
About defrost control, see this article: When the fridge is not cooling ...
To find parts and diagrams enter the model number in the links listed below, try all the links listed:
Where do I find parts and diagrams?
If you need to contact a technician use the Fixya directory (US only).
Regards.
Ginko.
Posted on Jan 27, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Sep 30, 2016 | Samsung Refrigerators
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
How do I fix a buzzing sound in my fridge?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 09, 2015 | Refrigerators
Frigidaire fgf379wjca wont stop beeping and diaplays door on control panel
When a cooling device starts beeping, see it as a warning it can't hold the temperature you selected. Could be the compressor does not work correct, could be it lost cooling fluid. If it keeps beeping, save the food by putting it in another fridge and start (or let someone start) finding out what is wrong. The door symbol is indicating the fridge thinks the temp rise is caused by an open door.
Jul 13, 2014 | Electrolux Dishwashers
Beeping
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
Apr 12, 2014 | Whirlpool Refrigerators
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
My Samsung Cool' n Cool Fridge Freezer it wont stop beeping. The doors are both shut and the appliance is switched on. I have accidently broken the little plastic mechanisim that opens and closes upon...
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
Aug 31, 2011 | Refrigerators
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Refrigerators Logo
112 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
