Question about Brother LS-1520 Mechanical Sewing Machine
Brother LS 1520 Everytime I try to use the satin stitch (for applique) it seems like the timing is off and the needle will hit something in the bobbin area every 5th or 6th stitch. Then either the thread tangles or the needle breaks. The machine will not do this with any of the other stitches (zig zag and straight stitch both work fine). I've taken the bobbin area apart, cleaned it well, and oiled it, but the problem still remains. Any solutions? OR do I just need to take it to a shop?
  • Michelle May 22, 2011
    I have changed the needle, cleaned it and oiled it. I hear a clunking sound around every 5th or 6th stitch (like the needle is hitting something). I just found it curious b/c it only does it with the satin stitch. All the others still work great so I was hoping maybe it was something I was doing wrong. Ah well, a trip to the shop it is!
    President:
  • 739 Answers
Hi..
before you decide to take him to the store.
try to check why did you experience a problem occurs.
Why does the needle keep breaking?
There could be several reasons why the needle keeps breaking.
1> Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
2> The needle could have been damaged or bent.
If so replace with a new one.
3> Make sure the fabric is not pulled excessively when sewing.
Let the feed dogs move the fabric.
Do not pull the fabric.
4> The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.
(example: Denim-size 16 needle and 40-50 heavy duty thread).
Related FAQs:
> Combination of fabric, thread and needle ( CLICK HERE )
but if the damage is found on your machine, the easy way you decide to take it to the shop may be right if you do not have the skills to repair the damage.
Please accept if your problem solve
Tq
Posted on May 22, 2011
  • Brother Master
  • 1,133 Answers
I presume you've changed the needle as well as cleaning and oiling it. If so, and you can hear something touching in the rotary hook then yes, it sounds like the timing is off, so time for a drive in the car to the shop. Certainly if its breaking needles then its got an issue.
How do I do a basic satin stitch ? My machine only has patterned satin stitches
A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
Mar 23, 2018 | Sewing Machines
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiRr76k0sbLAhXBKGMKHei6AfIQFggqMAI&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
Mar 16, 2016 | Bernina Sewing Machines
What can I do to widen my satin stitch when it is to narrow for the applique
Unless you have and know how to use digitizing software, will you be able to add width to the satin stitches when doing applique. You need to cut the applique fabric larger than the cut-out-line so the applique fabric will held down properly. Some Commercial or higher end home embroidery machines can re-interpret the embroidery design and widen the satin stitches in a design without software. 6f3dbcfe-19c3-4021-b143-de10c9a89868.jpg
Jul 14, 2014 | Brother PE770 Computerized Sewing Machine
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
Brother LS 1520 I was in zig zag mode and broke a needle. Now that I have replaced the needle, the needle thread will not pick up bobbin thread.
Are you sure that you replaced your needle right? The flat side must face the rear of the machine and did you put your needle on a straight stitch? I hope it didn't mess up your timing. But try this and I have my fingers crossed for you that it is something simple.
Dec 11, 2010 | Brother LS-1520 Mechanical Sewing Machine
When I stitch out my applique with my Brother SE350, sometimes the satin border doesn't align with the fabric tack down stich. It makes the applique look like a mistake. It looks perfect on my computer...
Check to see if it is a free design, sometimes this is why they are free. (they arn't perfect) or you could try and edit the design yourself and see where the problem is. It's not hard when you have been shown how, but far to complicated for me to explain, try and find someone (maybe in a machine embroidery club) to show you how. Good Luck!
Oct 07, 2017 | Brother SE-270D Computerized Sewing...
What foot do I use with the twin needle?
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Feb 09, 2009 | Brother LS-2125 Mechanical Sewing Machine
When appliqueing in stitch 11 the thread kees looping...
I believe stitch 11 is a zig zag so you are probably decreasing the length to get a satin stitch. You will get a better satin stitch if you select it directly. I think that it is about 29. The machine forms the satin stitch differently than the zig zag and it should look better. If you still get loops on top, you may need to have a qualified technician check the needle to hook clearance. If this distance is too great, the machine skips stitches and you will form loops. Several other adjustments may be needed to get a perfect stitch and a qualified Husqvarna technician should be able to take care of this problem for you.
Nov 23, 2008 | Husqvarna Viking 1
Brother LS-1520 Mechanical Sewing Machine Logo
47 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
