Question about Kurzweil Pcr1 Orchestral Rom EXpansion Board
Hi!! I Need PCR1 Orchestration and PCX Expansion for Kurzweil PC2x Thanks
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
I am looking for a manual for the Kurzweil Reader Model 7315-60.
Your best bet would be to contact Kurzweil Customer Service directly.Here isa link to their Support page-
Kurzweil Education
Feb 23, 2015 | Music
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
Kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Sep 25, 2012 | Kurzweil Music
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
I NEED KURZWEIL PC2X MANYAL
http://kurzweil.com/content/migration/downloads/pub/Kurzweil/Pro_Products/PC2/DOCS/PC2V3MAN.ZIP
May 06, 2012 | Music
Kurzweil Pcr1 Orchestral Rom EXpansion Board Logo
Top Kurzweil Music Experts
drivealot
john cordey
john cordey
rhodesworks
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
