Question about Canon PIXMA MP150 All-In-One InkJet Printer
The ink cartridge cannot be recognized ,but the ink cartridge was installed properly .Unfortunately,the ink was flowed out ,please tech me a proper manner to comb this problem as soon as possible
    Problem Solver:
  • 19 Answers
Hi, are you using the original ink cartridge or your ink was modified to CISS before? If you just finished refill your ink and this problem occur - the ink cartridge cannot be recognized, you shall take out both your ink cartridge and try to wipe the whole thing with a clean cloth and then carefully put in back. Hope it helps you. Good luck =)
Posted on May 22, 2011
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Tip
I am having canon pixma ip1300 inkjet printer. it worked properly till 13th...
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication cable. You will be moving it to a work area with excellent ventilation, such as outside.
c. At the far right where the the cartridges normally park themselves when not printing you will see a platform with rectangular compartments. When the cartridges park, this platform rises, seals off the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what looks like sponges in the compartments. This material with holes in it, like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
on Apr 15, 2009 | HP Officejet 5610 All-In-One InkJet...
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Color cartridge recognition MP160
E5
5 times
The ink cartridges are not installed [1401], or a non-supported ink cartridge is installed [1485], or the ink cartridges are not installed properly [1687].
Check if supported ink tank(s) is installed, and re-install them properly, and then close the scanning unit.
Sep 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Ink cartridge problem
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
790 people viewed this question
old marine
old marine
