Question about Jenn-Air JMV8000 Microwave Oven
How many watts is this microwave oven? - Jenn-Air JMV8000 Microwave Oven
How many watts are on the wst3501 microwave oven?
Westinghouse WST3501 Microwave Oven 0.7 model or 700 watt
Good luck (remember to rate this answer).
Apr 08, 2011 | Westinghouse WST3501 Microwave Oven
What is watts for goldstar MA 1280M Microwave and if it is over 1100 watts cani i adjust it down
You can set it to different levels. It is doubtfull the magnetron will deliver more than 750 Watts as that is about all they can produce singley. Commercial ovens use at least two magnetrons.
Most specs on microwave ovens quote the power drawn not power produced.
I hope that helps.
Jan 01, 2011 | Goldstar MA-1280M Microwave Oven
Question: Can the Tastiwave oven be used?
I don't own one but per the TastiWave Quick Start Guide (which can be downloaded as a PDF document), The wattage must not exceed 1300 Watts. In the Instruction manual and quick cook recipe guide (also a downloadable PDF document) it states that:
"The recipes in this booklet have been written for an 1100 Watt microwave oven. Please adjust your “cook times” accordingly. Microwave must have a revolving turntable and the interior
must measure at least 14” wide x 14” deep x 7 3/4” high".
I hope this answers your question ;-)
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MMV4184A 1000 Watts Microwave Oven: My microwave turns on but does not heat the food. ...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fsjf
May 18, 2010 | Maytag MMV4184A 1000 Watts Microwave Oven
Amana ACM2160A 1100 Watts Microwave oven doesn't heat
heatman101
56ik
May 13, 2010 | Amana ACM2160A Microwave Oven
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
How many watts on my microwave?
Hi
The wattages of your microwave is 800 watts.
Thanks!
Jun 15, 2009 | Emerson MW8985W Microwave Oven
Need small microwave for inverter on houseboat
Look at the rating sticker on the oven and use the AC power rating as your guide. The cooking power of the oven is not important, but the power it needs from the AC supply is. Voltage times current is the supply power needed (watts), and you want an oven that will draw less than the inverter's continuous rating, less any power being used by other appliances.
For instance, a microwave rated for 120 volts AC at 10 amps needs 1200 watts. Your inverter would be OK with this as long as other devices aren't using more than another 1000 watts. You can't use the inverter's peak rating. That's only for brief bursts, like when the microwave first kicks on and draws some extra current.
Any mid-power (600 watts or so) oven should be OK.
Apr 16, 2009 | Emerson MW8627W Microwave Oven
Jenn-Air JMV8000 Microwave Oven Logo
35 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
