Question about Pentax Cameras
Pentax opti w20 card locked - Pentax Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
SD cards have a slide switch along one edge.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Sep 20, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 69 Answers
SOURCE: Pentax Optio W20 digital camera
I found a step by step manual for this operation. I hope it helps you get to transferring movies. http://www.pentaximaging.com/files/manual/OptioW20_pc_web.pdf
Posted on Sep 04, 2007
  • 102366 Answers
SOURCE: Pentax A20 Opti: Card Locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Mar 09, 2010
zeronullity
ZeroNullity
  • 71 Answers
SOURCE: what driver do i need for a w20 pentax my pc is windows vista
You should be able to transfer pictures without any extra drivers/software. If I'm not mistaken this model uses mass storage driver... It should show up as a drive letter under "My Computer". It should show as normal hard drive, similar to a flash/thumb drive.
Posted on Nov 16, 2011
Which sd cards with higher capacity is available
A 1GB card is much larger than a 16MB card. That may be your problem. Most consumer point-n-shoot cameras would not be able to address a 1GB card. Try using a smaller-capacity card like a 4MB and see if it won't work.
Your owner's manual will tell you what size cards work with your camera.
May 30, 2014 | Pentax Optio W20 Digital Camera
Need updated software for pentex Optoi W20 , soft ware S-SW58
The page containing all Pentex software downloads is at:
http://www.ricoh-imaging.co.jp/english/support/download_digital.html
Nov 03, 2013 | Pentax Optio W20 Digital Camera
My computer does not detect my Pentax Optio w20 digital camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDsee or any other photo cataloging program.
Jun 09, 2012 | Pentax Optio W20 Digital Camera
What driver do i need for a w20 pentax my pc is windows vista
Nov 16, 2011 | Pentax Optio W20 Digital Camera
How to unlock my w20
To unlock the Sony ericsson W20 You can use the unlock code,You can get the unlock code and instructions from here
Theunlockspot.com
and Unlock it from Network lock,You can enter the code using the instructions below:
Sony Ericsson W20 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W20 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W20 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W20 without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Sep 20, 2011 | Sony Ericsson Walkman W205 Cell Phone
My Pentax Optio WP beeps 3 times, goes dim and turns off. The battery is charged up fully. Any suggestions?
Hi Jesslionbery,
Please try removing the memory card that has been installed in it , if any.
When you remove the memory card make sure it starts.
If the above trick does not work , try using NIMH battery instead of the ones that you have in and check if it works.
Also if you update the firmware of the camera , it may solve your problem, please find this link for more information , as the crashing problem has been resolved for many because of a firmware update.
http://www.pentaximaging.com/customer_care/show_firmware?firmId=6442215.
Hope this helps ..:)
Jun 28, 2011 | Pentax Optio T20, T10, A20, A10, W20, W10,...
My memory card is locked I can't take pictures or delete them.
There is a slider on the side of the card which you can move to unlock it
Jan 11, 2011 | Pentax Optio W20 Digital Camera
I think the battery was the problem...where can i buy and how much is the cost of it?
You can buy battery replacement for this unit from any electronic store near your area like best buy, or radio shack or you can get it from this online store , by the way the price range for the battery is $10 - $20.
http://www.batterycentury.com/pentax-optio-w20-battery-p-42693.html
Aug 13, 2010 | Pentax Optio W20 Digital Camera
Jun 16, 2008 | Pentax Optio A20 Digital Camera
Sep 04, 2007 | Cameras
Cameras Logo
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
