Question about Avaya Merlin Magix 4424D+ Telephone
MERLIN MAGIX R.4 WITH 412TDL NO DISPLAYS WORKING WITH 4424LD 4412D OR 4406 HAS TALK BATTERY AND MESSAGE WAITING LIGHT BLINKING. SWITCHED CORDS, CARRIER, PROCESSORS. ALSO TRIED 024TDL AND SAME THING. WHAT NOW?
  • 1 more comment
  • eflattsixfou May 23, 2011
    i have a merlin magix r.4 with a 412 tdl card and none of the 4400 series diplays work.i tried an 024 card, same problem. switched carriers, power supplies, jacks, anphenol cable. please help.
    h this happens with multiple phones and some are new in box ?
    are you an expert with merlin magix ? if yes please respond.
  • 12,061 Answers
Hi, well usually when this happens on ones i get into the shop, these are usually faulty in the area of the control CPU, and or the driver for the display.
Often it is bad soldering on the crystal or the PLL IC. In any event, this is NOT a problem that can be sorted by DIY.
To repair this phone it would have to be returned to the manufacturer, for a "Quote" as to the cost of the repair.
In all honesty though, most often repair isn't an option and the cheapest way usually is to obtain a new unit.
Posted on May 23, 2011
    President:
  • 2,047 Answers
Displays are usually simple connections. The problem with your display is one of 2 things either the backlight is bad therefore when you put it on the display remains normal and therefore looks like nothing shows. These lights are usually tiny LED bulbs and are difficult to spoil so first trace the source of power to them before replacing them.
The other likely problem is the display board itself being bad or the connection to it being bad. Try replacing the display board and also check the flex cable to the board for continuity. Once you check this the problem should be somewhere along those lines.
Hope this solution has been helpful?
  • 3,083 Answers
Since you've changed the processor, that leaves things like support chips, bad solder joints, and other nightmare scenarios. The blinking leds usually indicate a power problem, or non-functioning
section of the circuit, and the microprocessor incates this in that manner. Unfortunately, noone troubleshoots to the level that would really help you, since these things are designed to function and then be thrown away, and there's just no demand for any precise troubleshooting or repair expertise in this arena. You would need at least an oscilloscope, schematic, and engineering description of the circuit to be able to have a shot at pinpointing the problem.
Telephone lines are subject to spikes, as well as power lines, and herein lies most failures, since the spike can zap any number of chips, and even simultaneously, which is not cost effective to even try to repair.
My best shot would be to tell you to measure source voltages, and ensure they're on the power input pin of every chip. If you have a scope, you can verify the functioning of the cpu, more or less.
A schematic would be helpful to trouble-guess components that may have been damaged by a surge, but even this is difficult, unless you're familiar with the circuit.
Diodes are the old school way of protecting against surges, and can be suspect, still. There are what they call fusible links in many modern circuits, and they are very low ohm resistors that open with excessive surges. They are usually and ohm or less, and marked (color-coded) as resistors.
Brush up on your color code, measure any suspect small, resistor looking component, and replace any that are open.
Actually, that's the best shot, now that I think about it. If you have access to a scope, you will see the voltage die across the component, and can just poke around, versus ohming out.
Wish I had Merlin's ball for this one, and too bad the company doesn't have it for support!
Good luck, and hope this helps. You're going above and beyond where few have ventured.
AVAYA Merlin Magix phone system powers on, all phones have blank display but have message light blinking, no dial-tone, key press = no sound, adjust volume rings phone and displays on screen.
if you have it plugged into an outside line and do not have a dial tone call your phone company .but when buying stuff at an auction , well you get what you got even if it's old and none working
Feb 21, 2016 | Lands Phones
I have a Merlin Magix 4424LD+ phone and the display not working. I bought a new one to replace it but the display did not work either? Is there any programming caused this display to be off or stop...
Just to verify are you using a 4wire cable that has power? If you have moved environments it is possible you might have to get the aux ac power adapter that you plug your cables into to power the display.
May 18, 2011 | Avaya Merlin Magix 4424D+ Telephone
The date and time on the display disappeared. How
Is the light on your intercom red? Almost like the phone isnt hanging up. There is no way to disable the time on the display. Have you tried a new phone?
Jan 19, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
On the Avaya Phone System, how do you configure two phones to have the same extension. (4412D+)
You can not have 2 phones with the same extension number. But you can programm a "coverage" button on each phone. IF YOU HAVE A MERLIN MAGIX OR MERLIN LEGEND:
At the phone, press :
SPKR #00
Press a button, it will say on the display if the button is "Blank" or has another feature programmed on it. When you find a button you want to program, press it.
On your display will read "list features", press that button.
press the more button until the features listed are "Coverage". Press the button next to "Coverage"
now it will say "Primary", "Secondary" or "Group", Press "PRIMARY", then press the "enter" button on the display.
Next, enter the extension number you want to ring on your phone, and press the "Enter" button on the display.
When finished, press "HOME" to exit programming.
It has been a while, so I might have confused or flip-flopped the order of the extension/primary part, but you will see.
Repeat that for each users phone. Now, when their phone rings, it will ring on your phone as well, so you can pick it up.
IF YOU HAVE AN IP OFFICE:
GO into Manager, select the main extension, then go to the "Mobility" tab, check the "inteernal twinning" box, and select the 2nd extension. Save the config (will only be a merge)
Now when the first extension rings, it will ,make them both ring. If you make a call from the secondary extension, it will show as if you are calling from the main one.
Dec 01, 2009 | Avaya 4412D Corded Phone
How do I change the time on a 4412D+ avaya phone?
Assuming that you have a Merlin Magix and not an IP Office. You will need to do this on a 4424LD+, not the 4412, though.
Changing time on a Merlin Magix/Legend.
Nov 20, 2009 | Avaya 4412D Corded Phone
How do I change the number of rings before voicemail picks up?
The 4406 can be set up for a few different systems. What system do you have? Dial into voicemail and it will say what vociemail you have...
Jun 26, 2009 | Avaya Merlin Magix 4406D+ Corded Phone
Merlin Magix PRI
If D-channel is dropped, you will get red light.
When B-Channels are in use, you will get amber light.
Sep 08, 2008 | Avaya Merlin Magix/Legend Control Units,...
Avaya 4424LD Night mode
By pressing the night button. Is there a night button? Which system is it?
Mar 14, 2008 | Avaya Lands Phones
Phone set up
This phone is a Merlin Magix system phone. The time is stored in the main control unit, not the telephone. You have different times on different phones??? I do not see how this is possible unless the clock is broken and not updating the phones with the correct time. If that was the case every time you unplug a phone and re-connect it the time may be reset to 12:00 on that phone. Avaya has all their manuals available on their web site. I'd suggest going to www.avaya.com and searching for "Magix time"
Aug 28, 2007 | Avaya 4412D Corded Phone
Avaya Merlin Magix 4424D+ Telephone Logo
69 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
