Question about Whirlpool Washing Machines
F 02 blinks off and on. does not drain or complete cycle.
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
DISHWASHER WON'T DRAIN ANLY HAD IT FOR 6 MONTHS. CLEANED FILTER. DID NOT HELP. WHAT TO DO?
Hi, if its still under warranty you should call bosch and get them to arrange a service engineer to come out and check it for a fault.
Jan 15, 2016 | Bosch Dishwashers
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
GE Washing Machine won't drain or complete cycle model # WBCH6240F0GG
The power line might flick. That's why not complete cycle.
Before do any repair, samply plug a alarm clock to the outlet that
the washer plug to. Leave there for a while about 1 day. If it blink that mean there a flicker on that line or may be some other line as well.
If power line is flickering. Fix the line (Do not fix the Washer!)
Mai Lor
Feb 25, 2013 | Washing Machines
The washer right in the middle of a wash cycle it will stop and blink F02
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops about half-way through the cycle and displays an "02 F" message. I have to pause, then restart in order to complete the cycle. It sometimes does this twice per cycle. Any ideas what could...
This is the problem below.
F/02
Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
www.appliancehelponline.com
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
Oct 24, 2009 | Kenmore Elite HE5t Washer
Washer will not drain
Try to do a spin only cycle....if no good there, vacum water out with a shop vac and have a few towels handy and check your pump.
Jun 11, 2009 | Washing Machines
Washer will not complete a cycle.
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up.. be sureto use HE detegent this will eleminate "suds"
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not complete its cycle on any wash cycle. Error Code F 02 shows up before rinse and spin is complete. Clothes are soaking wet. What is the problem?
check the drain hose for any blockages or kinks and check to make sure water passes through it freely. it may be that it's just not emtying quick enough and therefore clothes remain wet. in a worse case scenario the pump itself could be faulty :(
Oct 27, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
